I never realized he moved them so much further forwards? That kinda sucks, especially for guys with big feet and MX boots.
I guess due to his wider peg he couldn't keep them at the original location, 1.625"s forwards is quite a bit though, that changes how the machine handles when you're standing on the pegs. MX bike pegs are further back than ATC pegs.
You wanted a nice clean look, spacers were the perfect solution. Hope you found some longer 10mm bolts from Honda (probably 15mm longer).
If anyone needs a longer shifter, they can use a 250SX shifter, or any steel shift or brake lever can be extended easily.
I wouldn't lose sleep over the extra leverage, the drum rotation is limited with stoppers in the engine cases.
That's why people can use suicide shifters without damaging the shifting drum or forks.
Although, with those being 2 feet tall, that's allot for the shift shaft itself to have to deal with unless there's an intermediate shaft...
