Hello everyone, so my 84 has what I think is bad chassis flex(best way I could describe it). If you grab the side of the hand grip and rock the trike side to side the chassis flexes before the rear tire will left off the ground. Also if you sit on the trike and lean side to side there seems to be a fair amount of flex/twist as well, almost like something will snap before it tilts over on its side. It has an extended swinger but none of the linkage setup just the shock. I thought that was it but iv seen other trike with that setup and they don't have the same issue. Any help would be appreciated. Thanks.
