Results 16 to 30 of 46
Thread: 1985 Kawasaki KXT250 Build Thread
    Jan 2024
    Amherst, NH
    69
    Test to see if this pic shows up.
    Jan 2024
    Amherst, NH
    69
    Ha - it did. Not my trike, but does anyone know what low profile rear tires are on that Tecate?
    I’m making ok progress - slow as usual. Rebuilt rear shock in place, went to install the rear axle last night and saw it’s also “tweaked” but not horribly, I’m going to try and straighten it out. The forks are installed, used the straightened tubes, I tried to source an alternate set (but failed unfortunately). I’ll post some pictures of progress in the next couple days.
    Las Vegas, NV.
    2,491
    Quote Originally Posted by sjsst41 View Post
    18x11-10 Fast Trekkers.
    Jan 2024
    Amherst, NH
    69
    Onto restoration of that radiator guard - can anyone give me recommendations on the paint code that should match up well to the new plastics? I’ve done some online research & read Kawasaki green paint k417 is a good match for late ‘80s lime green, but it’s not easily sourced stateside. All the PJ1 spray paints seem to be later colors as well (98+). Any feedback and experience is appreciated.
    Jan 2024
    Amherst, NH
    69
    Making progress !Click image for larger version.
    Jan 2024
    Amherst, NH
    69
    Another “snag”
    So I could tell the Mikuni carb that was installed on the Tecate wasn’t stock - it’s a flat slide - but figured I’d clean it up and see how well I can tune it (if needed) it seems to run well when I took the trike for a test ride - anyway the PO had removed the airbox and installed a small clamp-on canister filter. The extra parts included an airbox, so I reinstalled that, sourced a replacement cage (not easy) and installed a new UNI filter. Well as you may have guessed, the flat slide carb doesn’t fit in that stock space. Bummed to have to source a carb for this project, but I shouldn’t be surprised.
    I don’t want to bother finding a stock carb that’s 40 years old (and it’s strange the prices being asked on eBay for non-complete ones). I did a quick test fit of the Keihin PJ off my ‘86 ATC 250R, and it fit perfectly. I’ve read to look at the 35 mm PWK - but I might try to fire it up with the PJ and see how it runs. Any recommendations?
    Thanks !
    Steve
    Jan 2024
    Amherst, NH
    69
    Carb Pics
    Some photos
    Oct 2011
    Glamy's place
    95
    My brother and I run 38mm PWK A/S carbs on ours and they fit with the stock intake boot and airbox. The airbox boot is stretched a lot, but it works. I'm not sure dimensions are much different if any from that PJ you test fit. I ran a 38 on my stock tecate and it was great and it's great on my ported tecate. I'm sure a 35mm would run great too, but you will give up a little power up top.
    Jan 2024
    Amherst, NH
    69
    Thanks for the feedback - I don’t mind giving up some power, as I’m more interested in it being a good runner.
    Jan 2024
    Amherst, NH
    69
    Moving further towards completion. Tank, exhaust and electronics installed. Hope to start soon with the replacement carb in place.
    Las Vegas, NV.
    2,491
    Coming along nicely. It's looking good.
    Jan 2024
    Amherst, NH
    69
    Thanks ! Just finished up this morning before heading off to “mothers days” activities and I fired it up for the 1st time since the rebuild. Happy to say it started right up. Unhappy to say the aftermarket fuel switch leaks like a sieve. Any recommendations for a quality switch? The one that’s on there the PO installed, and a common eBay or Amazon $10 part. It doesn't look like a stock Kawasaki unit is available?
    Las Vegas, NV.
    2,491
    You're welcome. A few years ago, I rebuilt the OEM petcock on the Tecate I'm currently building. It was tested with water in the tank, and luckily it was leak free. We will finally be firing it up in the very near future, so gas will be going the tank for the first time, and hopefully it will still be leak free.
    For your situation, I would try ORI: https://www.off-roadinnovation.com/index.php
    Here is another helpful thread for Tecate owners: https://www.3wheelerworld.com/showth...ap-Interchange
    HondaRidr's Avatar
    Salt Lake
    343
    Some yamaha petcocks will fit on the tecate tanks as well. I think I used a timberwolf petcock or something like that on mine.
  15. #30
    Jan 2024
    Amherst, NH
    69
    Thanks again for the reference - good knowledge/info !
    I went with a Kawasaki petcock, OEM PN 51023-1342 for a KLX110 02-15, and it fit nicely.
