Results 1 to 15 of 46
Thread: 1985 Kawasaki KXT250 Build Thread
    Jan 2024
    Amherst, NH
    69
    Picked this trike up about a month ago with the intent to perform a semi-restoration. Nothing over the top, but address the items that need attention, and make a clean rider.
    It's currently torn down to the frame - which isn't in bad shape, I had to re-weld the coil mount back in place (held in place with a hose clamp)
    I received new KTX plastics kit, and a Clarke fuel tank (in Kawasaki green) new replacement stock graphics for the fenders and tank, and a replacement blue seat cover. I'll post of the fit/finish of all these parts once I get to that point (and I'll update this thread with pics)
    I did ride the trike when I made the purchase, it ran well, but with the motor out I removed the top-end, looks to have a stock bore with Wiseco piston kit, and a Pro-X connecting rod - pleased everything is tight and doesn't look to have many hours on the build.
    Also - the rear shock is blown, so that's out for rebuild (I hope it's in decent enough shape to rebuild) and I found out one fork tube is bent - so the plan is to straighten it out, then replace the fork seals.
    As expected, there's a long list of small items that need repair - but I'll save that detail for another post as I make progress.
    HondaRidr's Avatar
    Salt Lake
    341
    Looks like a solid start! Are those fenders and tank painted? I have not seen that color before.
    N/A
    5,818
    I can already tell you the forks are done for so there is no point rebuilding the forks with all that rust that will rip up the seals. You can have them stripped and re-chromed. Forking by Frank does make new replacement tubes. Getting somone to answer an email or a phone is going to be the hardest part.
    Jan 2024
    Amherst, NH
    69
    Quote Originally Posted by HondaRidr View Post
    Yep - the PO mentioned he painted them as the plastics were faded to almost white. I have new plastics and a tank waiting to get installed.
    Jan 2024
    Amherst, NH
    69
    Yeah the fork tubes are definitely on the edge, if not over, of being usable. I have them soaking in Oxalic Acid as I write this - that will typically do a fantastic job at dissolving rust, I’ve used this technique on many chromed BMX parts that looked to far gone to salvage. I’ll post up the results.
    Jan 2024
    Amherst, NH
    69
    I managed to strip the frame today of paint, which was a pain. Maybe tonight I’ll be able to get a coat of paint on it. The trike didn’t have the airbox installed (just one of those small filters with a hose clamp on the back if the carb). But the package deal came with a spare frame with an airbox, but no cage and no cover. I’ll have to fab a cage, but in a positive note, a fellow online has a 3D model he generated which is downloadable for a couple bucks. I did download and send it to a friend who 3D printed it for me, I’ll pick it up tonight and check the fit, I have my fingers crossed it works well enough.
    Jan 2024
    Amherst, NH
    69
    Making progress - although slowly - but that's how it goes. Frame, engine and swingarm painted, new swingarm bearings, top end gaskets (just pulled to inspect, but all was in-spec), new shifter that I need to extend (it was supplied with the trike when I bought it, a new EMGO shifter, but for a mid-80's KX250). New intake boot and chain slider.
    I'm headed to Norway for a month (business travel) on Friday - so I hope to have the triples and forks installed before I go, so the project will be stalled for a while until I return, but the rear shock should be finished by then. Also - I see the suspension dogbone heims are NLA - is there any recommended alternatives?
    Last edited by sjsst41; 02-14-2024 at 10:51 PM. Reason: Correcting stupid spellcheck errors
    Jan 2024
    Amherst, NH
    69
    Jan 2024
    Amherst, NH
    69
    And picture of the 3D printed Airbox cover:
    Las Vegas, NV.
    2,489
    Looking good. These things take time.
    Jan 2024
    Amherst, NH
    69
    As one of the engineers that used to report to me always said “Slow work takes time”.
    Jan 2014
    Massachusetts USA
    782
    Looking good! I saw this trike a while back on marketplace, glad it's in good hands and getting the love it deserves!
    1985 Tri-Z 250
    1985 ATC250R
    9,014
    Quote Originally Posted by sjsst41 View Post
    Haha! One of my personal favorites is “you do nice work… not much, but nice”
    Best of luck with your project
    It sucks to get old
    HondaRidr's Avatar
    Salt Lake
    341
    Off Road Innovation has a lot of parts for tecates including the dogbone bearings. Love to see another tecate getting some love!
    https://www.off-roadinnovation.com/kxt250-84-85.php
    Jan 2024
    Amherst, NH
    69
    Thanks ! I did see ORI shows dogbone heims on their site, but they state they are discontinued with no stock available. I might have to get creative on a replacement.
