No, but they had at least 3 versions of the 350X frame where they added a gusset to that left upper frame tube where they snap.
For some reason the seat latch areas seemed to break more on the 85's as wll, it's been a long time I may be forgetting something.
85 had nothing on that verticle frame tube, just the motor mount welded on.
The later serial numbered 86's had a nice wide and long gusset on the backside.
They also changed the upper motor mount bolts from 8mm to 10mm; some claim it's the flexing of the frame that cracks them, I always felt like the suspension was trying to separate the top half of the frame from the bottom. That's where there's only 1 bolt that doesn't join the 2 sides.
I use to wrap them with a piece of DOM tubing and then gusset that, and weld it all into the corner gusset. I made lots of posts about this maybe 15 years ago when I did a bunch of frames.
