will 350x rims fit on a 200x? or will 350x hubs fit on my 200x axle?
350 hubs won't work,But 250x or 300ex hubs will.The rims should fit.I have 300ex hubs with 400ex rims and 20x11x9 razrs on my 84 200x.It looks good and makes it a few inches wider.
300ex 400ex 250r 350x and 200x all use the 4 on 110 lug pattern so the rims are interchangeable.
84 ATC200X--Wife rode it once, now I can't get it back.
84 ATC250R--Trying to find piston for 300R kit.![]()
85 ATC350X--Project finally under way, slow progress. For pics: http://groups.msn.com/ATCfriends/350xproject.msnw
84 ATC200S--Freebie from a neighbor, needs topend rebuild and tires.
First off the 350x hubs do not fit a 200x axle. The 350x rims are the same bolt pattern as the 200x's. You didn't mention what year 200x so let me answer it this way.Originally Posted by vartiak15
83-85 200x's use a 4/110 bolt pattern rim. How ever the design and studs for these years are smaller and shorter than the 350x's. to safely use 350x rims on. 1 other thing, The 350x use a tapered style lug nut. The 83-85 200x uses a standard flat locking nut.
If you wish to use 350x rims on a 83, 84, 85 200x then you need to get longer studs and the tapered style lug nuts. You will also have to grind the 4 little tabs on the 83-85 200x hubs to allow the 350x style rims to sit properly.
The other option ( easiest ) would be to use 86-87 200x, 300ex, 400ex, and a few other style hubs and lug nuts.
Now if your 200x is a 86 or 87 model with stock hubs then the 350x rims will bolt right up.
Howdy
One other comment
The 300ex hubs will fit on the 200x axle,and they are extended about an inch on each side.
ATCnut
82 185s - sold
83 200x (hopped up)
84 200x (stock)
84 70 (lost this one to the DMV)
85 70 (soon to have lights, a foot brake, and CDI ignition)
84 200es (parts trike) - sold
85 350X (the best)
85 350X (siezed motor, dream of a poweroll kit someday)
85 250sx (frame was trash, got parted out)
86 250sx (the tractor)
86 250sx (a nicer tractor)
86 250sx (an even nicer tractor)
87 200x (parts trike, its really rough, a dog was chewing on it for a while)
87 250es Big Red (the tank!!)
