Thread: 2006 Suzuki LTR450 swing arm
    Mar 2024
    Lake Macquarie Australia
    28
    Hi guys
    Does anyone have one of these they can measure for me? They are steel I believe?
    I'm looking for the width:
    Across the pivot.
    Across each side where the bearings go.
    Distance in the middle where the engine goes.
    I cannot find any locally (in Australia) to measure and want to check one will work for me prior to buying from the USA with lots of $ freight.
    Mar 2024
    28
    I found one, in New Zealand of all places. It looks like the LTR swing arm is the same measurement across the engine at the pivot, but its about 6-7mm wider on the outside than the DRZ frame. I think it might be the same width as an RMZ. In any case it will fit with some mods.
    Williamstown PA
    5,825
    hreatv.com has stock ones. he builds all kinds of reproduction parts and custom ones. It might be easier for you to order a custom swinger for your project. Most times partzilla.com will list bearing sizes or bearing / seal numbers and you get can measurements in MM by looking / searching the bearing sizes.
    Mar 2024
    28
    Thanks mate. The initial build will probably be a trial and I'll get hreatv to build me one properly once its all sorted.
