Results 1 to 3 of 3
Thread: No Spark !!!!
    Sep 2007
    Canada
    26
    No Spark !!!!
    This title is one that I have seen many times in this forum. After metering several items at the CDI I have come to the conclusion that the Stator coil is not working properly. I do not get any OHM reading in the CDI pin or the connection where the wire comes out of the case. It seems odd to me that I get no reading at all. From what I have read I would need to replace the primary coil. I am not sure if I can find a stator assembly from any aftermarket supplier. If I am able to find Primary coil I will need to do a bit of soldering. If it is any of the secondary coils I am wondering if I can just replace them as well. I have not removed anything from the trike yet. If anyone else has had this issue if you could share info would be great. Thanks in advance.
    1984 200 ES
    Sep 2007
    Canada
    26
    It was the ignition source coil got it replaced and have a good spark and it fired right up.
    Arkansas
    2,428
    Thanks for the follow up.
    If you'd like to have some good info in case of future problems, record the voltage from the new source coil during cranking with it unplugged and with it running.
    Resistance specs aren't as good as voltage specs for a coil. They can test good but still not produce proper voltage. When testing resistance, the coil isn't working, loaded.
