Results 1 to 12 of 12
Thread: Another Axle ID Request
    Jan 2024
    Amherst, NH
    69
    Got this axle with the ‘85 Tecate I purchased, assuming it was a spare & I can confirm it’s not. Pics show dimensions. The major difference is the larger OD where the bearings sit.
    Any feedback is appreciated.
    Steve
    Attached Thumbnails Attached Thumbnails IMG_3025.jpeg   IMG_3024.jpeg   IMG_3023.jpeg
    Jan 2024
    Amherst, NH
    69
    So approximately 40 mm on the bearing ID that would be used on this axle.
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    422
    do the hubs in the photo fit the axle?
    TRX450ER
    ATC250SX
    ATC350X
    ATC110
    ATC185S (Marlboro Red)
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    Carthage NY 250r rules
    2,355
    It could be a Honda axle 85-89 250r, 400ex, 350x, 450r, use a 40 mill inner race .Also Suzuki Quadracer and Quadsport has 40 inner race size.
    250r rules
    Jan 2024
    Amherst, NH
    69
    Quote Originally Posted by Footy View Post
    They do fit that axle
    Jan 2024
    Amherst, NH
    69
    Quote Originally Posted by atc300r View Post
    Initially thought maybe a 250R, but the hub bolt spacing is much larger than what’s on a Honda (I have an ATC250R and was comparing). Maybe a Quadracer? I’ll do some more investigating. Thanks !
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    422
    Exactlly! The hub is something like 4 on 156mm. I think that is the bolt pattern for a 1990 model yamaha Banshee.
    I do not know the bolt pattern for the quad racer but I have a friend with a 1985 model so I can find out.
    TRX450ER
    ATC250SX
    ATC350X
    ATC110
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    Jan 2024
    Amherst, NH
    69
    Sounds like an early Banshee then, I see the Suzuki QR is 4 x 130 mm (via web search).
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    422
    Quote Originally Posted by sjsst41 View Post
    Yes my friend with the 85 model said that as well.
    I think 1989 and 1990 banshee used 4 on 156 rear hubs.
    Also the polaris scrambler 400 & 500 and 2003 predator 500.
    TRX450ER
    ATC250SX
    ATC350X
    ATC110
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    Jan 2024
    Amherst, NH
    69
    What’s odd is looking at ‘89 & ‘90 Banshee hubs don’t look like the ones I have:
    Las Vegas, NV.
    2,520
    From your post #1, you have what appear to be Tecate hubs. The hubs pictured in post #10 are indeed Banshee hubs. Both of the hubs in question have the same spline count, and will work on either axle.
    Jan 2024
    Amherst, NH
    69
    Got it - Thank you for clearing that up.
