Results 1 to 10 of 10
Thread: Yamaha Yt175 and yt125
    Sep 2024
    Ontario, Candada
    7
    Lightbulb Yamaha Yt175 and yt125
    Hello, I heard that engine parts from a yamaha dt125 will fit a yamaha yt125 parts like piston, cylinder, crankcase, seals, etc but not the clutches or transmission parts. Is this true? Also will Yamaha dt175 parts fit a yt175?
    Thanks
    6,809
    The dt175 bottom end is a manual clutch setup , it was a great upgrade back in the day for racing TT and flat track .
    Sep 2024
    Ontario, Candada
    7
    The yt125 engine needs new crank seals but other than that it is pretty good. It only has 90 compression hot but it sounds good and not rattling or anything. The 175 is gonna need a new top and bottom end, bad rod bearing. Maybe the cylinder is savable. Can I use a dt175 bearings, crank and piston? The year for the 175 is 1982.
    Jug will need to be bored oversized or replaced, deep gauges. Big end con rod bearing is completely gone, I do have a press and a lathe I could potentially rebuild the crankshaft. Obviously piston and rings need to be replaced although I seen on a thread that I can use yamaha blaster pistons if those are easier to source.
    As for the 125 would the dt125 or 175 crank seals work? I might also do a top end on it because it only has 90psi of compression and the piston looked a little rough through the exhaust port.
    Nov 2024
    Mississippi
    6
    I know this is an older post but I think the dt seals may fit. if not you can find new old stock seals on ebay. I recently replaced the crank bearings in my 1980 yt125 and i found the seals by searching for a 1980 tri moto yt125 parts diagram. the part number will be listed then searching that part number. anyway, Im sure youve made the repairs and moved on by now. lol
    Sep 2024
    Ontario, Candada
    7
    Its winter and I'm going to start repairing these now and I will take note of all of the interchangable parts with the dirtbikes.
    First off dt125/175 seals are the same as yt125/175 seals and so are the crank bearings.
    Sep 2024
    Ontario, Candada
    7
    Yt and dt 125 crankshafts interchange. It 175 and yt 175 connecting rods are the same but the crankshaft must be different. Seems like on both machines the cylinder and piston are not the same but the dirtbike or blaster piston and cylinder may still work on the three wheelers?
    Nov 2024
    Mississippi
    6
    will the dt125 cylinder (jug) bolt onto the bottom end of the yt? I assume it will but if Im going to do that I might as well just swap the engine for the dt 125, I can route a clutch cable to the left and maybe swap the hand lever for the rear brake to the right side.
    2,591
    I think that it will. I've seen it said the the DT/IT175 cylinders will bolt onto the YT175 bottom end. That makes me think that the same goes for the 125 engines.
    Sep 2024
    Ontario, Candada
    7
    Alright the dt and yt both have the same bore and stroke size too. I did hear one thing about chinese dt175 jugs are from australian bikes which have a shorter stroke.
    Feb 2025
    singapore
    The crankshafts between the YT125 and DT125 are interchangeable. This implies that the connecting rods and their associated Tapered Roller bearings are also compatible. The connecting rods in the YT175 and IT175 are identical, suggesting that the rod bearings are also compatible. However, the crankshafts themselves differ between these models
