Results 1 to 3 of 3
Thread: Hello!
    Sep 2024
    USA, AZ
    4
    Hello!
    Hi everyone! I'm new here. I'm the owner of a 1985 Honda ATC 250R, and I often run into the issue of uneven tire wear. Usually, I end up replacing all the tires to avoid problems. Is this a specific issue with this model, or is it common with all ATVs? What do you guys do in this situation?
    6,798
    I would think incorrect tire pressure or the terrain where you ride could be factors .
    Also put the Atc on flat level ground, handle bars straight and look at it from the front , the frames and forks bend fairly easy on that model .
    Sep 2024
    USA, AZ
    4
    I knew there was a slight bend where the fork starts, but I never thought it could be the cause. However, it's noticeable on a flat surface. Thanks for the advice.
