1984 Honda 200ES. Been in the family since new.
When trying to start, it will barely try to crank. Sounds like a dead battry. With the compression release engaged, it will barely crank enough to trip the release, then nothing.
Voltage drops to 6.7 volts at the starter, solenoid and battery. New battery, load tested as good. With the wire removed from the starter, there is no voltage drop. I removed the wire from the starter and solenoid and checked it with an ohmmeter and no abnormal resistance. Cleaned the connections and hooked it back up. Removed the ground wire at both ends, cleaned connections and checked with ohmmeter. Removed wire from battery to solenoid and cleaned the connections and checked the wire with ohmmeter. I made a new wire for between the solenoid and battery anyway, but no difference. I tried using a jump pack, no difference. I hooked a second battery in parallel with the new battery, no difference. In bought a new starter, no difference.
With the starter removed, it will spin and there is no voltage drop. When the starter is installed again, voltage drop and barely tries to crank.
I tried jumping the solenoid. Same result.
I unhooked the wire to the starter and jumped directly from the battery. Same thing.
It will start with the pull starter.
What am I missing?
is all I need to fix things, computers are evil and a 'back in my day' montage. I like it all for what it is, and often times, for what it's not, but it's in the understanding of it that brings everything into focus and appreciation. If I was to mention Buster Keaton, the majority of older people I know wouldn't recognize the name, like they don't know the film special effects pioneer Méliès, the running horse animated images by Eadweard Muybridge, if I mentioned the phrase 'To a rag and a bone and hank of hair' they wouldn't have a clue. Early German expressionist film Metropolis wouldn't ring a bell, nor would that most of the mainstream classical composers they have heard were German or Russian. They've probably heard Flight of the Bumblebee but don't know the tittle or composer, or even realize how long ago it was composed.
