Good morning,
I have an ATC 125M that has some pretty strange differences between Google searches of the ATC 125M & what I have. I don't have a frame or a VIN, just the serial number on the case. TE01E-5007357 The serial number is listed as an '86 ATC 125M. The problem is that it will spark/run for only 4 seconds, electric or pull start.
*It's mounted vertically,
*The cam side cover is a different shape & says Honda, not 125.
*Pulse Generator is inside the crankcase with the Stator stuff, not off the cam.
*The stator has 8 coils, not 4. I need one, it looks like what's in an ATC 250R but I don' know if it will fit. It has 2 wires to the rectifier, not 3. It puts out 45vac +/- when cranking but drops to zero as soon as it sparks for 4 seconds. It has voltage but can't sustain a load. It won't light the headlamp at all.
*The starter is different, I searched online for hours But I never found a new one that matched, I only found 2 used ones.
*It has a factory newer style 2 plug CDI.
*I've never found a service manual for it, & I'd love to find one.
*From Google, "1987 ATC125M's where fashioned to resemble the ATC185/200 models with a vertical up-swept engine. This sad fact explains the very low production numbers of the redesigned ATC125 model. The 1987 year model is even harder to find, once thought to not exist at all."
*It's on a workbench stand, I've checked every single wire and connection with a good VTVM. This engine will be going in another project, a 1967 Coot amphibious all terrain buggy.
What do I have & will an ATC 250M stator fit?
How do I add some photos of it?
Thank you.
