Results 1 to 8 of 8
Thread: 1985 200x and 1986 200x
    Mar 2020
    Georgia
    89
    Had a quick question about a part interchangeability for the 85 and 86 200x. I need to get a new muffler clamp for my 85 200x but nobody sells a new one, however, Honda sells a new 86 muffler clamp. Are the interchangeable? Honda has different part numbers for them but im assuming since they are both 200x models they are the same?
    Willamstown PA
    5,824
    Quote Originally Posted by Atc 200x 1985 View Post
    NOTHING 1ST GEN AND 2ND gen is really the same.
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    421
    This is a bit of a gamble but the 1st gen 200X engine is very similar to the XR200R dirt bike engine which was sold until 2002.
    You might have better success finding a clamp for the XR. Look at some photos online a try to tell if the clamps are similar.
    TRX450ER
    ATC250SX
    ATC350X
    ATC110
    ATC185S (Marlboro Red)
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    Arkansas
    2,447
    Same part for the ATC185S and ATC200S.
    No shortage of them on Ebay, although many aren't pretty and probably need thread repair. I think there's an NOS one on there now.
    If you're not concerned with originality, stainless T clamps are a lot less of a headache and will more likely come off next time without breaking a bolt.
    And no, the 85 and 86 200X clamps aren't the same. The 86 uses a more modern clamp, with two bolts, similar to what later Honda dirt bikes used. The XR200R up until 2001 uses the same clamp as the 86 200X.
    Willamstown PA
    5,824
    You really do not need the clamp. Take the header and muffler to a weld shop. Have them cut off the part on the muffler that needs clamps due it 4 finger design. Any shop can install a peice of tubing to fit the correct length needed and weld back onto the muffler.
    None of my machines with OEM mufflers use those clamps. Just gotta use the brain and think out side the OEM parts box
    Nov 2024
    Toronto
    7
    he '85 and '86 200X are pretty similar in a lot of ways, but Honda did make a few tweaks between the two years, which is probably why the part numbers for the muffler clamps are different. That said, it's very possible they’re interchangeable since the exhaust setups are nearly identical.
    If the clamp looks the same and the diameter of the muffler and frame mounting points didn’t change (which I don’t think they did), you should be good to go. Worst case, you might need to do a slight modification to make it fit perfectly.
    If you’re unsure, maybe grab some measurements off your current clamp (or where it mounts) and compare it to the specs for the '86 clamp before you buy. Or hit up someone parting out an '85 if you want to play it super safe
    Nov 2024
    Toronto
    7
    The '85 and '86 200X are pretty similar in a lot of ways, but Honda did make a few tweaks between the two years, which is probably why the part numbers for the muffler clamps are different. That said, it's very possible they’re interchangeable since the exhaust setups are nearly identical.
    Arkansas
    2,447
    Quote Originally Posted by thomaskwar View Post
    About the only same similar between the first and second gen 200X is the name.
    There is no tweaking, Honda completely redesigned it.
