Results 1 to 12 of 12
Thread: New to me 200x.
    Feb 2017
    Corona CA
    827
    New to me 200x.
    Didn’t get the survivor , no paperwork. Would have been a nice bike but when there out of the system in California it’s a lot of money and hassle. Got this rougher version. Had title and registration. Picked it up cheap. Needs a seat cover. Plastics are ok oem. Tank is ok no rust on inside. Minimal outside.
    Didn’t run. Swapped out the fuel carb and changed the oil. Seems to run ok. Has a cobra exhaust repacked with fmf packing. New plug and air filter. Maybe 60$ and it runs ok. Blows a little oil smoke. Hasn’t ran in like 5 years so hopefully just needs to reseat. Gonna adjust the valves next weekend. Worse case I’ll do a piston and top end over the summer.
    Wheels and tires and seat cover incoming.
    Any recommendations or ideas for the oil smoke after it’s been sitting ? Cleans up when it’s warmed up. Valves stem seals ?
    Arkansas
    2,439
    For something that's sat a while, but runs, you can try to fill the cylinder with a product and let it sit a few days. Mystery oil, Seafoam, whatever. You'll need to change the oil afterward though.
    If the rings and ringlands are dirty, it may clean those enough to so the rings fully seat and it may cut down on the smoking. The valve guide seals get hard and maybe riding it for an extended time will soften those up, a little, but it won't fix anything. Maybe all just enough to cut down on the smoking.
    Otherwise, just ride it and see what happens. A little smoke at startup isn't a big issue to many people, as long as it's not being a big oil user and fouling plugs.
    If I pull and engine down, it's likely to start a runaway project that gets a bit over what I intended at the start. Basically, every little thing I notice wrong is going to get some attention, even rusty bolts. I can't hardly just pull one down for a top-end job and put it back together without making it evident I put some time into it.
    Feb 2017
    Corona CA
    827
    Gonna ride it and see what happens. Nothing far or fast. My kids first atc so taking it easy. I have a whole extra engine. I’ll rebuild that and drop it in summer time.
    patriot1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2020
    Palestine, AR
    398
    Ride it like you stole it!
    Feb 2017
    Corona CA
    827
    Quote Originally Posted by patriot1 View Post
    Maybe me , but the kid has state championships 2 weeks after we go riding so , nice and slow little buddy. Haha.
    IDK if the 1st gen motor was quiet even right off the showroom floor. The timing chain and guides always seem to make a scratching, scraping, ticking sound, even with the valves in spec.
    Still a fun trike, inexpensive, easy to get parts for, easy to work on, easy to upgrade, there's a reason Honda made so many of them.
    Can't run them low on oil, or crappy oil, or it smokes the cam journals.
    Feb 2017
    Corona CA
    827
    Some upgrades today. Put my older kendas on new rims from my 350x onto the 200x and installed the footpegs / heel guards from swamp outlaw. Got some more stuff but have too many things to do. Wrestling tournaments tomorrow , invasion next weekend. Then state championships week after. Got the serwa tires for my 350x. Like the look. Hope there soft like the Kendas.
    Feb 2025
    Poughkeepsie ny usa
    3
    Nice trike! Good luck with it. And yes it's more than likely the valve stem seals causing your cold smoke. Does the spark plug show any signs of oil? I also agree with the seafoam fill soaking in the cylinder for a day or so. Just to get a good de coking of the rings. Also run a good oil. Maybe some bestline oil additive. I'm not a huge additive guy. But that stuff REALLY cleans things out carbon wise.
    Feb 2017
    Corona CA
    827
    Quote Originally Posted by Neald View Post
    Yes the plug has oil in it. It has good compression so I think it’s the stem seals as well. I have a whole extra engine with a frozen crank but looks to be a perfect top end. I’ll probably just have a valve job done on my extra head and put it in.
    Feb 2025
    Poughkeepsie ny usa
    3
    Sounds like you know what needs done. Good luck with the project!
    Feb 2017
    Corona CA
    827
    Probably
    Gonna try stem seals as I have the adapter for the cylinder to pump it up with air (if it holds I know I’m right) and there 9$
    -and then tear my extra motor down this summer after my should surgery and build something a little wilder.
    Arkansas
    2,439
    I haven't bought one yet but it sure seems like a good deal instead of fussing with an old stock head and trying to get more out of it.
    Honda XL185 XR185 RS200 cylinder head 2 X BEARING CAM HIGH LIFT, BIG VALVE
    https://i.ebayimg.com/images/g/hGUAA...8bm/s-l960.jpg
    https://www.ebay.co.uk/itm/276685895...temCondition=3
