Thread: 185s stuck flywheel
    Apr 2024
    SE Louisiana
    6
    185s stuck flywheel
    Picked up a 1981 185s last March, and went from sitting to running thanks to this site!
    Put the machine to work prepping the deer lease this past summer. Saved my butt a lot of walking and packing gear in and out, but she's better put to use ripping up the trails! Anyway, the honeymoon is over, and I have her torn apart for a top end rebuild.
    Everything was going well until I decided to pull the flywheel to replace the lighting coil. I cannot get this flywheel to budge, and now the crankshaft is starting to mushroom!
    First attempt with the flywheel puller, the flywheel did not budge, so I tipped the engine on it's side and filled the flywheel nut cavity with penetrating oil and let it soak overnight. No luck, flywheel still didn't budge.
    Have since tried moderate heat to the flywheel, lots of heat to the flywheel, cycling heat/penetrating oil, and whacking the puller/flywheel with a with the puller bolt cinched tight. Nothing!
    What else can I do?
    I need a hail Mary as I think I screwed myself by applying too much heat and ruining the excitor coil. She's no longer ohming to spec. If I can't remove the flywheel this engine is dead!
    Thanks!
    Sent from my moto g stylus (2023) using Tapatalk
    6,818
    Usually tension from the puller and a light wack of the will remove the most stubborn ones .
    As a last resort as to not destroy the crankshaft I would just cut the flywheel off with a cut off wheel and replace everything .
    Apr 2024
    SE Louisiana
    6
    Dang, easier said than done. Looks like I'll have to cut away the left/flywheel cover first to cut away the flywheel. But I think I'm at that point. Then fingers crossed that I can repair the threads!
    Looking at flywheels/covers on eBay. Were these all stored in saltwater [emoji38]?
    Thanks for the input.
    2,447
    Have you tightened the puller and left it to sit overnight?
    In case it pops loose during the night, a box with rags or other soft items could be used to catch it if it falls off. That'll prevent the flywheel from hitting the floor and possibly cracking the magnets.
    Apr 2024
    SE Louisiana
    6
    Well, I meant to take care of this "next weekend..." But, here we are 4 months later and I'm finally getting back to this project.
    I ended up having to cut and grind the flywheel off the crankshaft and I won't be able to salvage the crank.
    I split the case today to get a headstart on cleanup and assessing everything else. I'll be scouring eBay and Marketplace for a good crank or decent bottom end to salvage parts from.
    Anyway, just checking back in to let you guys know that I appreciate the input and didn't ghost y'all!
    And for my brethren and sistren wrenching down here along the Gulf Coast, WHY?!?! Why does it have to be so hot? lol. I waited until the wrong time of the year to get this project going again [emoji3062]
