Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Thread: SlikWillie's Build Thread
    Mar 2025
    Silverdale, WA
    15
    Yeah, I am not a fan of the plastic tanks. They just don't look right on a 185 in my opinion. This will look good from a distance, not so much up close. But I don't mind as long as it holds gas without leaking.
    1982 Honda 185S "modified"
    "You don't stop riding because you get old. You get old because you stop riding."
    Mar 2025
    Silverdale, WA
    15
    Ok. It's been a while. Sorry for that. Been busy with all kinds of stuff, and none of it was with the 185. But today, I got some time with it. The gas tank is all sealed up. That tank was the hardest thing that I have ever welded. The metal is so thin that I was blowing holes left and right. A lot of lessons learned there. I'm not going to lie, I did use just a little JB TankWeld in a couple spots. I was just sick of blowing through the tank and thinking I was done. But, she's solid now. Sorry I don't have pics of all of that. I'll post those later.
    After that, I decided to take the seat pan out to look at that. Or shall I say, what is left of the seat pan. What are you guys doing for these pan replacements? I can't find anything online. And the ones around my region on marketplace are in pretty much the same condition.
Name:	Rusty seat 1.jpg
Name:	Rusty seat 2.jpg
    2,447
    That's pretty typical.
    I suggest cutting you losses and spending the money to save the time. Also, it's a flex against the stupid high prices for used junk.
    I was able to put one of these in the cart, so maybe they're actually available.
    https://www.atcheaven.com/index.php?...scription=true
    If the foam is still good and you use an inexpensive cover, you may get out of it for less than $200 and basically have a new seat.
    Mar 2025
    Silverdale, WA
    15
    Thanks, ATC King! That's a fair deal for $125. The cushion is in good shape. The cover can be replaced while I'm at it, but those are relatively cheap. Thanks again.
