Results 1 to 10 of 10
Thread: Go to method to restoring plastic
    Sep 2016
    Ohio
    44
    What is your method to restoring some fairly weathered plastic? I recently purchased a fender off of fleabay, it was described “ ok” but did leave out that the fender was weathers and has some pretty good sized scratches in it. I’ve heard/ seen in the past that one can wet sand and buff the fender to bring it back, I’ve also read about the use of heat guns. Just curious as to what you guys prefer. Also I can’t seem to post pictures on here, or else I would do a before and after pic.
    Arkansas
    2,447
    Elbow grease and patience.
    Don't use a heat gun except for finishing. If there's any weathered plastic on the surface and heat is used, it'll just embed itself in the good plastic underneath and be nearly impossible to remove. All the damaged/weathered plastic needs removed first, then a heat gun can be used to put a final finish on it, bring some color back.
    Basically, the worst of it will be best physically removed. Razor blade, a progression of sanding paper, and other methods that are slow enough to keep an eye on the work without taking too much off at once.
    The more labor, the better they'll look when done. Trying to go fast and use some product at the end to cover what's left won't hold up. There aren't really any shortcuts if it's to hold up to close scrutiny.
    May 2015
    San Diego, CA
    1,797
    Kings right.......there's no secret magic trick. It's monumentally time consuming.
    I think the hardest part is going through all the sanding stages...that takes forever. All the faded, oxidized plastic needs to be scraped off with a razor, along with scratches, etc. If you take your time and be careful with the razoring you can reduce the sanding time considerably. Plus it's very rewarding to scrape off the old and reveal the new.
    Don't use the heat gun unless you need to. On lighter colors you can brown it sometimes before it flash melts. Buffing should suffice.
    Good luck
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    412
    What about removing spray paint?
    I have seen videos that recommend using Aircraft paint stripper for removing paint from plastic.
    TRX450ER
    ATC250SX
    ATC350X
    ATC110
    ATC185S (Marlboro Red)
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    Arkansas
    2,447
    At a factory I worked, we used heat guns to 'repair' minor blemishes in new plastic parts.
    At the end of each assembly line was at least one repair station and heat guns got plenty of use, especially when a batch of plastic parts we received weren't handled with care or the place that made them let some machine issues slip by before recognizing. Plastic injection molding machines can get temperamental and pump out quite a few questionable parts before someone notices.
    Arkansas
    2,447
    Quote Originally Posted by Footy View Post
    That's a different issue, and about a coating. Like anything, do a test in a small area before proceeding. If you really wanted to test something and save money, you could try brake fluid. I'm not suggesting anyone runs out and tries it without due diligence, just saying that it could work, and cost less than any paint stripper. That's one reason some vehicles us silicone based brake fluid, so it won't ruin the paint if spilled. DOT 3,4, 5.1 all should take paint off, but DOT5 is silicone and won't.
    My question would be why they painted them and if it was a quick job on nasty plastic or they done it right and just for a color change. I've painted several fenders, and most of them was because they looked bad, or were too rough to restore. Anyone removing the paint from those is going to find a lot more scratches than they thought. It's not like they can just remove the paint and polish the plastic, hence the reason why I painted them to start with.
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    412
    I bought a yamaha wolverine and the crazy old man that had it tried to turn it into a hunting rig. Camo overspray everywhere. It looks terrible but has less than a 1000 miles on it so I want to make it decent.
    TRX450ER
    ATC250SX
    ATC350X
    ATC110
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    Arkansas
    2,447
    What's wrong with camo?
    I mentioned brake fluid because I know there's people use it to remove paint from plastic. I won't personally suggest it because that's not what it's made for and there will always be someone who doesn't fully comprehended the responsibility on their end and would get upset if it didn't work like they thought. 'I read it on the internet' types.
    I also just put it out there because many of the stripping products available to the public are pure rubbish anymore and will barely do anything to paint without a lot of physical work, which is the whole point in using a chemical stripper to start with. The ones that do work are expensive. Anyone that's used off the shelf strippers twenty years ago are longer, remembers how well they used to work. Not anymore, a total waste of money and time.
    The aircraft stripper on plastic, I'd be concerned with and certainly wouldn't just go full blast with at the start. Plastic is pretty tough stuff for chemicals, which is why some form of plastic is used as a liner in metal chemical containers, but it all depends on the combination of chemical and plastic. Some chemicals will quickly soften/dissolve some plastics.
    I don't know what plastic brake master cylinder reservoirs are made of, but the fluid doesn't harm them one bit. Conventional DOT3 doesn't cost much and the cheapest brand out there should work. If for some reason you remove the paint but decided to repaint, cleaning the residue needs considered. Maybe it cleans easy enough, or maybe it will cause issues with even a minuscule amount left behind. It's not a paint stripper and there's no directions for that use.
    I don't guess Wolverine and Timberwolf fenders would swap, or I could help save you some effort.
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    412
    I appreciate your thoughts on this. I tried brake fluid a while back. It did nothing. I also tried regular paint stripper. Also did nothing.
    I have the 2nd gen wolverine 450. The fenders are more similar to a YFZ450. I wanted a fully automatic atv for family and friends that want to ride but have less atv experience, (ie: I do not want my manual clutch machines to get screwed up by novices.)
    Also I do not want novice riders on my ATC's. So this wolverine is good for that.
    TRX450ER
    ATC250SX
    ATC350X
    ATC110
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    Arkansas
    2,447
    Thanks for sharing that brake fluid didn't work in your application.
    It's difficult to restore old plastics and many people have tried many things. It's enticing to try easier methods, but manual labor tends to give the best results. People who haven't put forth the effort to restore older plastics don't comprehend the time it takes, which is why just using some aftermarket plastics is a better decision if it's a build to sell.
    The people who know will spend the money for restored OEM plastics, and frankly, everyone else can pound sand.
