Results 1 to 3 of 3
Thread: What the stuck ?
    DSHOT59's Avatar
    DSHOT59 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2009
    sayreville nj
    155
    What the stuck ?
    Starting my auto x project went to pluck the engine off an 83 200 I had lyin' around, for a while. Seems the engine mount bolts are stuck, real stuck. The bottom one and the one in the rear of the engine. Anyone been down that road and care to share some tips ? I warmed them up a bit beat them up a bit, Anyone had any luck before I try and cut them and not hurt the engine or the frame ???
    No trike left behind
    1983 Ytm 200
    1983 Honda 200
    1982 Honda 185s
    1983 odyssey fl 250
    1987 yz 250
    Arkansas
    2,447
    I guess it's that time of the year, people are starting their projects and finding frozen parts that didn't thaw after winter.
    Same old suggestions about heat, penetrate, and patience. If they'll spin, trying to walk them out with an impact can work. May have to lightly tap on the end with a while trying to walk it back.
    I know people suggest heat, an you understand this, but a lot of times it takes higher heat than a propane torch can produce, when parts are really locked together. I wouldn't want to apply that much heat to aluminum engine parts though, just steel frame and suspension parts.
    The one thing I don't suggest very often is an air , simply because good ones are expensive and many people don't have the setup to support the more powerful s. Those cheap s are nearly worthless, only good for very light work. A good air is much more effective than swinging a large hand . The high frequency of strikes can get stuck parts moving when a hand just smashes them.
    Most recently, I used an air to easily remove the cone washers from a pair of Aisin locking hubs. Doing it any other way would have taken way more time and possibly damaged parts, and there were already plenty of damaged parts on that job. A short brrrp on the end of the studs and the cones spat out.
    One bit I don't have is with a recessed end, that'll hold itself on a bolt end, so it doesn't go bouncing off. An air just isn't a tool I use that much, but when I need it, it's a serious time and hand saver. I probably use them the most when replacing suspension and steering parts on passenger vehicles.
    DSHOT59's Avatar
    Mar 2009
    sayreville nj
    155
    I have a good Matco air and a compressor was going to try that as a last resort. As I figured it would probably wreck the bolts at least.And I had hoped to reuse them, It seems they are stuck in the engine itself not the metal sleeves. So i was kinda leery about the heat thing also. Also have an impact wrench but was not sure if it would crack the cases trin to spin it. Thanks for the reply i'll keep at it and hope for the best,it's not supposed to be easy after all,right ?
    1983 Ytm 200
    1983 Honda 200
    1982 Honda 185s
    1983 odyssey fl 250
    1987 yz 250
