Thread: Honda missing drain hose on carb. Is it necessary?
    Mar 2025
    Kansas, USA
    18
    Rebuilt the carb on my honda 185s and afterwards noticed I never had a hose coming off the bowl or bottom of the carb. I think it's for overflow? Is it necessary? Is there any issues associated with not having it. Goofy question but no shame in my game. I wouldn't even know where to route the hose.
    Aug 2015
    Idaho
    855
    It’s a good question, really. I suspect most don’t drain the carburetor after use. But I believe that is what it is for. The hose takes it down where you can collect it and save it.
    Las Vegas, NV.
    2,531
    I would say, having hoses on the carburetor overflow nipples will make for a more difficult path for foreign matter (dirt & water) to enter the carburetor. Mainly, any overflowed fuel (if hoses routed correctly) will be directed below and away from machine, thus preventing a potential fire hazard, as well as keeping your machine looking tidy.
    Aug 2015
    Idaho
    855
    I’d also say if you don’t drain the carburetor after use then there won’t be a problem not having one. Unless the drain screw leaks because the o-ring failed.
    Feb 2016
    Stellenbosch, South Africa
    196
    For me personally, I use it as an indicator if the float is stuck or not, I only get to ride like once a month, so I drain my carb (yes the hose does make it easy to collect) every so often from sitting the float will get stuck and I can quickly see the hose spitting fuel after I open the fuel valve. One quick tap on the fuel bowl with a screwdriver handle and I'm good to go.
    1983 Honda ATC250R
    1984 Honda ATC200E BIG RED
    1983 Honda ATC200X
    1984 Honda ATC200X (sold)
    1985 Honda ATC70 x 3
    1985 Honda ATC200ES BIG RED (FatCat Conversion)
    1985 Honda ATC250ES BIG RED
    1986 Honda ATC250ES BIG RED
    1988 Honda ATC250ES BIG RED
    2001 Honda TRX90
    2002 Yamaha Breeze 125 (sold)
    2004 Honda TRX300EX (sold)
    2008 Honda TRX250TM
    1976 Suzuki RV90M (sold)
    1967 Vespa Primavera 125
    1958 Massey Ferguson 35
    Aug 2015
    Idaho
    855
    I didn’t even think about the vent hole above the bowl. That’s a great observation I hadn’t considered. My BR 200e has that vent tube but the 350 is missing and although I don’t ride it every day it gets used. So Ill get that tube replaced and thanks a lot red rider and busboy for the topic.
    Dec 2013
    West Virginia
    102
    No, it's not necessary. It's just a tube that allows you to drain the bowl of gas to the ground (cough) I mean safe container (cough) for storage/repair or when your floats stick. Helpful to have if your floats do stick so you're not pouring gas onto your engine... fires happen pretty easily.
    Proud Owner of:
    1986 400ex Frankentrike
    1986 Honda ATC 350x
    1987 Honda Big Red 250ES
