Originally Posted by
Jd110
Ok, looks good. Blowing air through the center hole would do no good. If you study the 2nd picture I posted, that’s your cap.
It has that plastic cup which has a one way valve at the bottom of it. You can blow air through the cup, but not back up it.
So when the switch is on I think it releases pressure so air can be drawn through the cup into the tank.
When switch is off it pushes down on that tiny plastic button and spring, sealing it off with the little oring.
Your fix looks like it should work fine. Let me know if you need another cap. I got an extra…
