Results 1 to 3 of 3
Thread: 250es cylinder removal
    rustyhondas's Avatar
    rustyhondas is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2006
    Missouri
    319
    Do I need to pull the engine to get the cylinder out ?
    I know I can sneak the head out , but will the cylinder slide up and out too?
    I’m wondering in the chain guide will stop me or something ,do I need to get a stud remover to pull the studs out to un pin it from there to clear the frame ?
    Im a mechanic,not a problem with the work or any improving just never done this one before ,thanks .
    Also shes getting a 10:5-1 piston on a std. bore should I leave the jetting alone to start has a 135 main now.
    86 atc 250r
    85 atc 70
    84 atc 200s
    05 650 rincon
    06 400at rancher
    93 lt80
    02 kx65
    6,802
    Top end can be done without removing the engine just takes a little finagling .
    The higher compression piston probably won’t affect the jetting, but to be sure just do a plug chop .
    Dec 2013
    West Virginia
    98
    Quote Originally Posted by rustyhondas View Post
    I can't answer your question, but can comment on removing the studs if you need to do that: you don't need to buy a tool to remove them, just take two hex nuts that thread on there and snug them against one another, then use the lower nut to back the stud out.
    Proud Owner of:
    1986 400ex Frankentrike
    1986 Honda ATC 350x
    1987 Honda Big Red 250ES
