Results 1 to 2 of 2
Thread: 350x choke
    Sep 2007
    California, USA about 50 miles north of sacremento
    976
    350x choke
    Choke related question. The choke will stay in full choke position but if you move to mid choke after a second it will automatically pop to no choke. Its like something is pushing or pulling on it? Best way to explain is its hard to find the mid choke position and keep it there. Like its not a well defined mid choke position. Either choked or not. The hell am I missing???
    Whats up bud!
    Unlike the 200X carb, that has spring steel on it that holds the choke in a "detent" position, the 350X seems to have positions built into the plastic choke valve itself. And it has a torsion spring to help the choke go back to the "no choke" position.
    Remove the metal lever, grab a 13 or 14mm?? wrench, and unscrew the plastic choke part (the plunger) and you'll probably see what the issue is. It could just be that piece that is worn out...
