Originally Posted by
Busboy
Yes original carb. Everything original on the bike. Can you explain a little bit on what you mean by the idle circuit? Diagnosing or fixing it? I'm new to working on these or anything like it. Always just riding them
I think he is referring to an issue with the pilot jet.
I have an ATC110 that behaved similarly to what you are describing. I had to try multiply slide needle clip positions before It would start and run consistently.
Seems like mine ran better after lowering the needle (or raising the clip position).
Also having the foam filter on will make some difference.
TRX450ER
ATC250SX
ATC350X
ATC250ES
ATC110
ATC185S (Marlboro Red)
XR100R
CRF230F
Raptor 125
Breeze 125
Grizzly700
