Results 1 to 3 of 3
Thread: -Help-Honda atc carb leaking bad from bowl overflow
    Mar 2025
    Kansas, USA
    18
    Ran out of gas yesterday. Filled up the tank today and as soon i open up the valve on the tank for fuel to flow it begins pouring out of the bowls overflow or drainage spot on the bottom of bowl, directly out of the hole where a hose could connect. Never noticed any leak before.
    Las Vegas, NV.
    2,531
    Either your float is hung up and not closing properly, the float seat is not sealing properly, or there is some debris in the float seat preventing it from sealing properly. Time for a carb clean.
    Mar 2025
    Kansas, USA
    18
    Thank you that did the trick
