Has anyone here replaced the steering stem bearings on an '85 250SX? I went with this kit from 223 Cycles: https://www.223cycles.net/store#!/Ho...it/p/521591788
So here's the problem I'm having. The instructions say to measure the height of the original lower bearing with some balls and the race, and then that will determine whether or not to use the spacer that came with the kit. Well, I had to destroy the original lower bearing (which was already missing some balls) to get it off the steering stem, so I didn't have anything to measure. On a hunch, I used to the spacer. Well, now I can't get the stem far enough through the neck to screw on the steering head cap. To make matters worse, I'll have to destroy the new lower bearing to get it off the stem in order to remove the spacer. Great, another $50 down the drain to buy a second kit just to get a new lower bearing. Ugh.
Was I wrong to use the spacer and I'm actually overlooking something that is not allowing the stem to be threaded on? (Yes, the lower race is tapped in as far as it will go into the neck) Just want to be 100% sure before I install another lower bearing onto the steering stem.
This is why I'm not a mechanic...I always seem to F things up.
Edit: by the way, that link is somehow taking it to the page for the 200X bearings, which is not what I ordered, but I'm guessing they are the same. When I copy and paste the link, somehow it changes from a 250SX link to a 200X link. Weird.
sorry i had too. I cant answer your question though either i like my balls.
330 CT RACING
