Results 1 to 2 of 2
Thread: Questions about 1984 200S
    Jul 2025
    Molalla, OR
    I bought a 84 200S that need to be put back together. It is mostly complete but missing a few things that I can tell. I need a recoil starter, brake levers, plastics front and rear, a seat, and probably more I'm not thinking of. The throttle lever is there but seems to be messed up so I may need to replace that too. I'm curious if anyone can help me by sharing info on which of these parts would be interchangeable from other trikes. My buddies are pushing me to buy cheap Amazon stuff to get it going but Id like to put it back together with as many OEM Honda parts that I can find.
    Tionesta, PA
    5,744
    You are very correct - forget cheap amazon parts - buy as many OEM Honda ATC parts as possible. eBay is your friend. the 200S was made from 1984 - 1986 - all parts are interchangable. For your pull start - 1981-1983 ATC185S will also work. Keep in mind with pull starts - later models had an automatic decompression set up that are cumbersome to rebuild and hard to find parts for - they are NOT needed to work.
