Thread: Wonky forks.
    Sep 2018
    Orange County Indiana
    5
    Wonky forks.
    I'm working on a 85sx. I've replaced the steering stem bearings, fork seals, boots, and front wheel bearings. I'm ready to put the new wheel on, but the forks are about 3/4" to wide and the axel is not parallel with the handelbars. I've had the forks out and back in a couple of times now with the same results. Has anyone ran into this before? I'm trying to figure out where I went wrong. Thanks.
ID:	271869Click image for larger version.
    Aug 2016
    East of Worcester ma
    1,369
    If i'm understanding correctly what your describing, your forks are bent are they usable sure why not. You need to find out which fork or both are bent, un do the top clamps and rotate one or both until things line up at the bottom. only a slight bend is needed to throw the bottom off, its multiplied the longer the forks are. Hope this makes sense to you. I'm willing to bet at one time in the bikes life or more the front end got pushed back enough to bend both forks, when u removed them they werent put back the same position so now one or both are bent sideways.
    the top of fork will rotate separately from lower fork
    Hope this helps
    Sep 2018
    5
    Well, it turns out that the base of the steering stem is bent. I bought it off of eBay, and it was so clean that I didn't even check it. (Never again). Now it's not to say my forks are not bent, but I'll find out soon. Click image for larger version.
    Aug 2016
    1,369
    Wow, yup that'd do it too. I'm surprised the forks slid all the way through theres pretty tight tolerances when lining up the fork clamps.
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    418
    I have had a lower triple clamp to be bent before. The best test is to put it on a glass table top.
    If it wobbles side to side like a Walmart shopping cart then you know the clamp is bent.
    TRX450ER
    ATC250SX
    ATC350X
    ATC110
    ATC185S (Marlboro Red)
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
