Thread: Tri-Z Gearbox Problem
    Aug 2025
    World
    4
    Hi there,
    Got an 1985 Tri Z 250. doesnt run, cleaned the carb cleaned gastank, air nox, new filter, new spark plug, engine starts idles perfet, at first i cant it in gear because the gear selecter rod were broken, i replaced that and put in new gear box oil, so i can shift all gears but if i release the clutch lever it doesnt start driving, so clutch looks good, oil is new, i tried different setting at the clutch pressure srew as well as the adjuster at the clutch cable. clutch cable is also not broken.
    Some ideas what could be the issue here ???
    THANKS
    9,020
    Remove the oil filler plug and look inside with a flashlight while you or a friend is pulling the clutch lever in and releasing it. Can’t you see the clutch plates opening and closing?
    It sucks to get old
    Aug 2025
    World
    4
    Thanks for this Advice, yes its moves, we take a look with my endoscope cam, see Video here if the clutch pack moves enough
    clutch discs looks good to me on the metal discs no blue color or similar
    what could be the problem here ?
    How much gearbox oil comes in, it says on the gearbox 10500cm3 ??? which seems a lot to me i filled in 1,0 Litre
    https://www.youtube.com/watch?v=F32y9Q7GE4I
    Aug 2025
    World
    4
    ok i think i instaled the clutch cover plate not according lining up with the arrow.... i will take a look cebaise there is no play in the clutch lever
    Aug 2025
    World
    4
    ok i sortet it out the Problem was the adjusting screw and the clutch pressure plate alligned with the arrows, works now. thanks
