Results 1 to 12 of 12
Thread: 1985 Honda ATC 110 Throttle Bog
    Aug 2025
    Fennville, MI USA
    6
    I have two trikes, both 1985 Honda ATC 110s. Both of them bog hard and stall out when I pin the throttle. I'm at a complete loss for how to fix this issue.
    They start on first pull and idle fine. Carbs are both set at about 3.5 turns out, and the adjustment screws can be turned out completely with no changes to idle. Seems to be running rich (black plugs), but acts like it's starved for fuel. Will throttle up perfectly when the choke is on.
    Here's everything I've tried:
    -Carb - cleaned and rebuilt, checked float height, played around with jetting
    -Air filter - installed new, checked, cleaned, tried running with it off (to no avail)
    -Timing - retarded and advanced timing (for what it's worth, one is so far out of timing, I can't get F mark to line up with any adjustment
    -Spark Plugs - replaced more than twice
    I'm no small engine pro, but I am pretty handy. Any thoughts? I appreciate any suggestions.
    Apr 2003
    Spanaway, WA
    1,248
    Can you throttle them up slowly? Do they only bog with fast throttle movement or all the time?
    The farther you back the air screw out the leaner you're making it, run it back in to 1-1 1/2 out and retry.
    Hoarder of the finest junk
    '82 YT175
    '83 YTM200
    '85 KLT110
    '86 Moto 4 225
    '84 TRX200 trike conversion.
    '87 Tecate 4
    Aug 2025
    Fennville, MI USA
    6
    Yes they will throttle up slowly okay. After the RPMs are up, I can be more aggressive on the throttle, but from idle, fast movement on throttle will bog them out to a stall.
    I believe the mixture screw is a fuel screw, as it's after the carb toward the engine.
    6,811
    Are you running the factory air boxes or just pod filters ?
    110s are very sensitive and need a complete factory air box to run correctly .
    Aug 2025
    Fennville, MI USA
    6
    Factory airboxes with Uni air filters.
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    437
    I have a 1983 110 that was a barn find.
    After I went through it and got it running it ran poorly and would not accept throttle input very well.
    The solution that I found was to lower the slide needle. It runs much better now.
    TRX450ER
    ATC250SX
    ATC350X
    ATC250ES
    ATC110
    ATC185S (Marlboro Red)
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    6,811
    Yeah Footy I was going to suggest the same thing , if your needing the choke on to accelerate then its wanting more fuel .
    Try lowering the slide needle clip which will raise the needle and that will give it more fuel .
    Aug 2025
    Fennville, MI USA
    6
    That's what I suspected also, so I tried that. No luck. Still having black plugs, still not running well.
    I have a suspicion that it may be a timing issue. Does that sound like a possibility?
    6,811
    You mention they will throttle up fine with the choke on so it sounds carburetor related to me .
    What brand carburetor kits ?
    A lot of cheap kits will come with the wrong size jets and parts .
    Best kit to use is shindy .
    Aug 2025
    Fennville, MI USA
    6
    Carbs are OEM with Shindy rebuild kits in both.
    I was also thinking carb issue, but the fact that I have black plugs and can't make it run too rich with the adjustment screw makes it a real head scratcher...
    Apr 2003
    Spanaway, WA
    1,248
    I'd check valve lash and cam timing next.
    '82 YT175
    '83 YTM200
    '85 KLT110
    '86 Moto 4 225
    '87 Tecate 4
    Aug 2025
    Fennville, MI USA
    6
    Thanks for the input. Just got a Clymer manual so I'll take a look. When I get some time I'll give it a shot and report back.
