Results 1 to 3 of 3
Thread: Front fork upgrade.
    Sep 2016
    Ohio
    45
    Front fork upgrade.
    I’ve got an 82 200 with solid forks and have an 84 parts bike that has a really nice set of forks with the shocks on it. Anyhow knowing the front tire is a different size, on each model.. chi had thought about trying to put the larger tire on the S model forks. If not I can certainly buy a new tire for the S model rim. Does anyone have any pics of a smaller front tire with larger rears to show what they look like? Also is the S model front rim the same size as the 82 200 with the larger tire?
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    442
    The 200s uses 22x11x8 tires. I think the 200 (no letter) uses 25x12x9 tires.
    You could use the 200s front forks with a 22x11x8 front tire and then use 22x11x9 tires on the rear with your stock rims.
    Or run it with the different height tires from front to back.
    I would not try to use a 25x12x9 with the 200s forks.
    I do not think those will be wide enough or tall enough.
    TRX450ER
    ATC250SX
    ATC350X
    ATC250ES
    ATC110
    ATC185S (Marlboro Red)
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    Sep 2016
    Ohio
    45
    Quote Originally Posted by Footy View Post
    I wonder if the shorter front tire would be THAT noticeable? I wasn’t sure if I could use the same rim or not.. I have both 200s rims and the regular 200 rims. The 200 right now is at a different location so I’ll have to wait to measure when it gets back. Thanks for your reply!
