Thread: 350x 250r hybrid
    Sep 2025
    oregon
    350x 250r hybrid
    ive come across an unmolested 350x frame the other day. i have an 86 trx250r motor that i want to try to make work in it. i havent seen a single post about this and wondering if anyone has experience with this. a buddy told me about swapping a 450r swinger onto it for a couple extra inches... The frame is obviously quite large for the motor so i feel it would make fitting easier except for the pipe. any input would be appriciated
    devore,ca
    1,054
    Is it just the frame ?. If it is, it’s going to cost quite a bit for the rest of the components. The engine you have is like a chunk of gold. If you could find a 85-86 ATC 250r roller with a blown engine it would be the direction I would go. Anything could be adapted into any frame. I’ve seen twin cylinder 250cc engines stuffed into an ATC 70 before.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    Sep 2025
    oregon
    I have a complete roller, basically just need to install the engine and make the pipe work I think is going to be the main problem
    Feb 2017
    Corona CA
    858
    I’m with Bob. Find a 250r with a junk motor you’ll have a better bike.
    The 450r swinger isn’t a direct swap , takes welding for the pro link and some fab work. Call HRE they have done it. You don’t get a lot of bang for your buck. And your subframe isn’t ready for it.
    You’d be better off swapping a 400ex motor into your 350x. Matt did one a few years ago and was pretty extensive on the build here.
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,249
    Quote Originally Posted by BOB MARLIN View Post
ID:	271929 hey man i know what that is!!
    devore,ca
    1,054
    I remember cool that “70” was !. ^^^^
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    RZR XP 900
