Page 1 of 7 1 2 3 ... LastLast
Results 1 to 15 of 99
Thread: 350X refresh questions
    Oct 2006
    Utah
    82
    Hey fellas, Our 85 350X that my dad bought new has been a dune machine for as long as I can remember. No clue on hours but this engine has never been opened up—ever. Still runs like new no issues to report. This winter I’m going to give it a frame gusset kit (much needed) and I’d like to freshen up the top end. What can I do to give it a little more giddyup?? I ride it twice a year at St. Anthony other than that it sits. Was thinking a wiseco 10.5:1 piston and a cam would wake it up a bit? What should I replace or inspect while I’m in there?
    Thanks for any help,
    Andrew
    1985 Honda 350X
    Feb 2017
    Corona CA
    858
    Quote Originally Posted by rot box View Post
    Andrew
    If you’re gonna do the piston go with the 12-1 , Webb cam , 400ex carb and a good exhaust (HRE header with a 450r muffler) and port then head if you have the money or know how. This will give you a real reliable machine and really liven up your experience. Of course this gets pricey , I would for sure do the 400ex carb you could get a used one on eBay (you’ll need a 400ex throttle cable as well) and while you have it apart get an EBC heavy duty clutch kit for a 300ex
    Oct 2006
    Utah
    82
    Thanks for the reply Shawn, would a 12:1 require race fuel? Was kinda hoping to keep her on 91.
    1985 Honda 350X
    Feb 2017
    Corona CA
    858
    Depends on conditions. If that’s real concern then use the 10.5-1. My bike will run on 91 if it has to but I wouldn’t run it hard or dune ride like that. When I go to the sand once a year for the invasion I run pure unleaded 108 VP. Most of the time I mix it 50/50 with 91. (100 octane) and it runs great. Keep in mind most of your modern efi 450/250/‘s run on 91 and have 14-1 comp. Granted they are water cooled and the efi compensates for fuel / air ratios depending on exhaust temp / and humidity all that fancy stuff. Higher octanes in a high comp air cooled bike will help keep it cooler. This is what I was told by the guys at racetech who did my machine work / head porting. I guess it just depends on how much power you wanna squeeeze out of it.
    Oct 2006
    Utah
    82
    Thanks again man I appreciate the help.
    1985 Honda 350X
    devore,ca
    1,056
    I run all my 350’s with a 10.25:1 wiseco. They run better than stock, start better and it seems to add a bit of torque. Plus they really don’t care what fuel you run. Add an old supertrapp exhaust and you’ll have a real nice running very dependable machine. If you want real HP gains you’ll have to go with what Shawn suggested.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    Oct 2006
    Utah
    82
    Thanks for the reply Bob, speaking of exhaust I currently have a Cobra and it is too LOUD! I’m thinking (if I can’t track down a supertrap) I’ll cobble together a 450 muffler. Anyone know what years work best? Looking for one with a spark arrestor...
    1985 Honda 350X
    devore,ca
    1,056
    Ya, the cobras were kinda loud. I have a nice DG on one of mine but the thing is so loud my ears ring after a long ride.
    Someone will chime in on the 450 muff. I have no experience with that, but I know it’s been done .
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    RZR XP 900
    Feb 2017
    Corona CA
    858
    Contact HRE atv , I believe they are in Pennsylvania, they make and sell a header that will work with any modern (2008ish) 450r TRX muffler. Stock or aftermarket. I used a Lexx from rocky mountain atv. Comes with a spark arrestor and a quiet core. Up to you , I’m running just the arrestor but it sounds great. You can always find an eBay stock muffler I’m sure.
    Oct 2006
    Utah
    82
    Thanks fellas, a Lexx would be perfect! I’ve ran them on dirtbikes in the past great results.
    I’m going to start pulling it down soon. It’ll mostly be a winter project looking forward to breathing new life into the ol’ girl.
    1985 Honda 350X
    Feb 2017
    Corona CA
    858
    Make sure when you order it get a later model I think 08 and up other wise you’ll get the wrong gasket. Easy fix and Rocky Mountain sent me one free of charge but takes time. Talk to the HRE guys they know what year to order.
    Jan 2014
    Prescott az
    725
    I have a 400ex big gun silencer on mine with a custom head pipe. I put it on YouTube how it was made.
    [/SIGPIC]
    85 350x
    83 200x-sold
    ×2 85 200x-sold
    06 kx250f-sold
    86 tecate-sold
    86 tri z powervalved
    85 BIG red
    18 rmz250
    87 lt80
    19 ttr110
    Oct 2006
    Utah
    82
    Thanks again fellas
    1985 Honda 350X
    Oct 2025
    Oakley
    Quote Originally Posted by 6spdls1z28 View Post
    link to the build?
    The OEM stock TRX450 muffler was a nice upgrade, but it wasn't doing you any favors in performance and it's large and heavy. Honda used to off an HRC tip for that exhaust, I still have one. It replaced the stock tip and put a much larger diameter tip on there. If you can find a DG head pipe (they seem to be about the biggest diameter), but if I recall, the Cobra headpipe may have been a fairly large diameter as well. Unless someone just but a Cobra onto the OEM head pipe? If you find a DG headpipe, then you can mate it to a better flowing, lighter silencer. Like the Big Gun mentioned above, a Supertrapp, a Yoshi, or any other exhaust used on the TRX 450R. If your head flows well it has to get out of the exhaust well too.
