The OEM stock TRX450 muffler was a nice upgrade, but it wasn't doing you any favors in performance and it's large and heavy. Honda used to off an HRC tip for that exhaust, I still have one. It replaced the stock tip and put a much larger diameter tip on there. If you can find a DG head pipe (they seem to be about the biggest diameter), but if I recall, the Cobra headpipe may have been a fairly large diameter as well. Unless someone just but a Cobra onto the OEM head pipe? If you find a DG headpipe, then you can mate it to a better flowing, lighter silencer. Like the Big Gun mentioned above, a Supertrapp, a Yoshi, or any other exhaust used on the TRX 450R. If your head flows well it has to get out of the exhaust well too.
