Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 31 to 45 of 64
Thread: 350X refresh questions
  1. #31
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,245
    the XR400 head pipe is a direct fit also its stainless and shorter in the back that is what i have used on several 350x's the original guard is nicer tooClick image for larger version.
  2. #32
    Oct 2006
    Utah
    68
    ^ that one looks killer!
    1985 Honda 350X
  3. #33
    Oct 2006
    Utah
    68
    Been busy today taking the mighty 350X down to the frame. ALL motor mounts were compromised in some way—yikes. Thinking I’ll do the swamps gusset kit I like the looks of that one
    I’ll try and figure out how to post pics and take you guys along for the ride.
    1985 Honda 350X
  4. #34
    J!m's Avatar
    J!m is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2024
    New Haven, CT area
    157
    I look forward to your thread!
    Here's mine: https://www.3wheelerworld.com/showth...-350X-project)
  5. #35
    Las Vegas, NV.
    2,521
    Quote Originally Posted by rot box View Post
    I like to go on rides. Bring it on!
  6. #36
    Oct 2006
    Utah
    68
    Sweet thanks guys! I’m making some nice progress on the ol’ girl. Cleaning off barnacles and clusters of goo/grime from the 1980’s haha.
    1985 Honda 350X
  7. #37
    Oct 2006
    Utah
    68
    Anyone have experience upgrading the ball bearings to taper bearings in the steering stem? My ball bearings are in rough shape. Is this truly a bolt in kit or? Trying to wrap my head around how they fit…. Thanks
    https://bvctrikes.com/products/taper...ng-bearing-kit
    1985 Honda 350X
  8. #38
    Las Vegas, NV.
    2,521
    I installed a set of All Balls tapered bearings (which is probably what BVC sold you) into an '86 Tecate steering head. It should be very similar on the 350X. Just pound out the old bearing races, from the steering tube, with a drift/. If there isn't enough of a lip on the old races, to catch & push out with the drift, you'll need to carefully cut them out with a dremel/chisel. Once they are removed, clean up the steering tube, then install the new races by pounding them in with a block of hard wood, and a . Do not hit the races directly with the . Always insulate the races, from the blows, with the block of hard wood. Go slowly, and make sure they go in straight, and all the way until they are fully seated in the head tube.
  9. #39
    Las Vegas, NV.
    2,521
    I almost forgot. The hardest part of the installation will be getting the steering stem pressed out of the lower triple clamp/bearing. Once removed, the old lower bearing and seal can be swapped out for the new bearing and seal. Then the steering stem will have to be pressed back into the triple clamp/seal/bearing.
  10. #40
    J!m's Avatar
    Nov 2024
    New Haven, CT area
    157
    Instead of tapping the races, I suggest a length of threaded rod and some washers or a couple blocks of wood with holes drilled for the threaded rod.
  11. #41
    Oct 2006
    Utah
    68
    Sweet thanks everyone
    1985 Honda 350X
  12. #42
    Oct 2006
    Utah
    68
    What’s the best way to clean 40 years worth of barnacles and goo off this engine without damaging the paint? I’ve tried dawn dish soap and a scrub brush but it’s not really doing it…
    1985 Honda 350X
  13. #43
    J!m's Avatar
    Nov 2024
    New Haven, CT area
    157
    I'm a fan of Brakleen and a toothbrush personally.
    But paints vary, so ALWAYS TEST. But usually, I have very good luck with this on many things...
  14. #44
    GeoD's Avatar
    GeoD is offline At The Back Of The Pack Arm chair racerFirst time rider
    Carbon County, PA
    169
    Give McKee's 37 engine degreaser or WD-40 Specialist Cleaner & Degreaser a try.
    Geo D
    1+2=ME
    My Toyz
  15. #45
    J!m's Avatar
    Nov 2024
    New Haven, CT area
    157
    I actually had another thing to add. I recently tried simple green foaming coil cleaner. Designed to clean a/c unit evaporator coils. Spray and wip or spray and wash off. It works well!
