Results 46 to 60 of 74
Thread: 350X refresh questions
  1. #46
    Oct 2006
    Utah
    71
    Thanks fellas I’ll give those things a try. I think the paint is in good shape just crusty/gooey.
    1985 Honda 350X
  2. #47
    Oct 2006
    Utah
    71
    Gonna crack the engine open soon. Wondering what I’ll find? I wouldn’t dare guess the miles/hours but it’s definitely up there! Doesn’t smoke, still has plenty of compression etc. We’ve never so much as checked the valve clearance. Been one hell of a good machine. Anyway I’ll take a close look at the cam journals and rockers etc.
    Wish I knew how to post pics haha. Many failed attempts..,
    1985 Honda 350X
  3. #48
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    427
    Quote Originally Posted by rot box View Post
    You have to use the feature that says"Go Advanced". Also the photo size has to be small.
    TRX450ER
    ATC250SX
    ATC350X
    ATC110
    ATC185S (Marlboro Red)
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
  4. #49
    I can only do it on my phone now. We used to use Tapatalk which was a pain but it worked, or we'd upload pictures with photobucket (which often disappeared years later).
    If you changed your oil and or ran good oil, I'll bet you'll find the bottom end is perfect and the crank will be fine too. As well as the cylinder head journals and camshaft, even the valves if there was no smoke (valve seals can't hurt). I've been in quite a few 350X motors and the timing chain guides just don't seem to wear out (unlike the 200X), only the timing chain stretches over time. You probably just need a complete gasket set, a top end, and maybe a clutch. Even the kickstart gears last forever on these motors. The ATC350X is an excellent engine!!
  5. #50
    Oct 2006
    Utah
    71
    Thanks again fellas I appreciate the help. I’m to the point I can start welding on the swamps brackets. Kit looks great, it all seems to fit good, nice instructions as well.
    1985 Honda 350X
  6. #51
    Oct 2006
    Utah
    71
    Well I have all my brackets welded on. Swamps did a great job of putting this kit together
    Time to get it ready for powder coat. Honda R109 is what I’m after does that sound right? I’d like an exact match on that red and possibly add a little metallic to make it pop. What do you guys think?
    1985 Honda 350X
  7. #52
    J!m's Avatar
    J!m is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2024
    New Haven, CT area
    169
    Do they offer a replacement muffler mount bracket? Mine has been cut off…
  8. #53
    Oct 2006
    Utah
    71
    Anyone have experience with upgrading the steering stem ball bearings to roller bearings? I see they offer roller bearings but I’m wondering how well they fit?
    Quote Originally Posted by J!m View Post
    I’m not sure on that one. I’m gonna say it’s unlikely
    1985 Honda 350X
  9. #54
    J!m's Avatar
    Nov 2024
    New Haven, CT area
    169
    Could someone with their mount intact trace it and scan it along with a ruler for scale? I can laser cut anything, but I don't have one to reference... I'll make a clamp-on option (like I need) as well as an exact replacement for weld-on. Assuming there is any demand beyond me for this.
  10. #55
    J!m's Avatar
    Nov 2024
    New Haven, CT area
    169
    Guys- I bought a box of ten taillight bulbs. If anyone needs one, let me know. I doubt I'll go through ten in my lifetime...
  11. #56
    All Balls, Moose, etc, they're all the same steering stem kit. The only issue is "do I use the washer under the lower bearing or not?"; the instructions are generic.
    I take out all the old bearings and races, stack them up and measure the height. Compare that the the kit, and that tells me what to do.
    Otherwise, if you use the washer under the lower bearing and don't need it, you'll run out of threads on the stem with the adjustment collar (the one with spanner grooves). And you can't remove it without damaging the new bearing pressed on the stem.
    The kits fit so many models that they can't give specific instructions. I usually toss the stem and lower clamp in the freezer and the bearing goes on easy, just don't hit on the caged needle bearings, use a piece of pipe that only hits the inner race.
    Be aware, lots of people ruin these kits installing them. Just take your time, triple check and be careful.
  12. #57
    Oct 2006
    Utah
    71
    ^thanks for the help I appreciate it
    1985 Honda 350X
  13. #58
    Oct 2006
    Utah
    71
    Trying to post some pics haha. Got the frame back from powder coat and it turned out fantastic.
    I just reused the ball bearings in the steering stem. Cleaned them up and added fresh grease.
    1985 Honda 350X
  14. #59
    Oct 2006
    Utah
    71
    Attachment 272044
    Scored a sweet AC grab bar to replace my stock one. Stock one had one too many wheelie overs on it hahah
    1985 Honda 350X
  15. #60
    J!m's Avatar
    Nov 2024
    New Haven, CT area
    169
    I've been absent here, but busy regardless. Front end is going back together now. New Serwa tires mounted, triple going back together with rebuilt forks, rebuilt front hub, rebuilt front brake master etc. (I wish it was easier to post photos) I am posting a bunch in "Pushing Retro" on Farcebook.
    But I have a question about the rear fender. I have found exactly one useable rear fender in several years of looking (1986) and I am thinking Meier is the way to go. But the backend is not cool. Even with the dedicated decal solution.
    Therefore, has anyone ever successfully altered the shape of the rear of the fender, to be more like the OEM shape? Basically, a single angle bend and flat edge. It seems to me that this could be heated with a heat gun and clamped between some aluminum plates to make the change. But before I move forward with testing (on my current old one), I wanted to see if this has been tried and ideally what the outcome was when it was tried.
