Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
Thread: 200M Clutch Slipping
    Nov 2019
    Florida
    1,048
    that is the take-off clutch or centrifical clutch. if its slipping in the upper gears, than its the friction disc and plates that need changing, also the tension coil springs get.
    still an easy fix, EBC makes a good kit that includes the plates/disc and springs for less than $100
    MrC.
    mrc_builds on YouTube Channel
    My Addiction
    85 350x "The Nice One"
    86 350x
    85 350x "Yard Sale" Flat Tracker
    84 250r "lucky"
    85 250sx "Enterprise"
    85 350x "Code Red"
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    83 Z50r
    85 ATC 70
    88 KD80x
    85 CR250r
    84 KXT250r Tecate
    DDQ's Avatar
    DDQ is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2015
    Aberdeen, NC
    429
    Thanks. So if the clutch is slipping in low gear that would indicate the centrifugal clutch?
    Also, I ordered the oring and gasket for the centrifugal clutch. The gasket is listed as 'oil filter gasket', but there is no oil filter, right? Part #2
    Attached Thumbnails Attached Thumbnails Screenshot_20251004_100452_Chrome.jpg
    DDQ's Avatar
    May 2015
    Aberdeen, NC
    429
    The fibers and plates all measure within specs. The only component of the clutch that measured outside spec was the shoes on the one way clutch.
    This site will not allow me to upload a photo right now which confirms the earlier discussion that the site owner is not maintaining it and will soon be abandoned.
    The clutch when you first take off, while sitting still and in gear, is your centrifugal clutch. Then the main clutch (plates/springs) takes over.
    And if you have the stud/nut mechanical adjustment that only pertains to the main clutch. Too tight and the main will slip, too loose and there is excessive free play. I've also seen people force the mechanical arm (under the clutch cover)over the splines in the wrong spot, making it misaligned an unable to function properly. Should have dots to align, or a flat on the shafts to align them, but people do all sorts of dumb things.
    DDQ's Avatar
    May 2015
    Aberdeen, NC
    429
    Maybe the fibers were glazed over then. Regardless, I have replaced the fibers and discs with a tusk kit. I bought a used complete 1 way assembly off ebay that looks to be in good condition. I am working on getting off the inner hub gasket which is hard as a rock and taking a long time.
    DDQ's Avatar
    May 2015
    Aberdeen, NC
    429
    Day 1 at LSOK 2025
    Attached Thumbnails Attached Thumbnails Screenshot_20251022_085516_Gallery.jpg   Screenshot_20251022_085529_Gallery.jpg   Screenshot_20251022_085557_Gallery.jpg
    Nov 2019
    Florida
    1,048
    good information to have, thanks
    MrC.
    My Addiction
    86 350x
    84 250r "lucky"
    85 350x "Code Red"
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    83 Z50r
    85 ATC 70
    88 KD80x
    85 CR250r
    84 KXT250r Tecate
    DDQ's Avatar
    May 2015
    Aberdeen, NC
    429
    To update, replacing both the centrifugal clutch with a used unit, and the fibers with a tusk kit has fixed the slipping.
    DDQ's Avatar
    May 2015
    Aberdeen, NC
    429
    Clutch is working.
    Attached Thumbnails Attached Thumbnails Screenshot_20251110_222918_Gallery.jpg
