Page 2 of 10 FirstFirst 1 2 3 4 ... LastLast
Results 16 to 30 of 145
Thread: Let the games begin! (1986 350X project)
    Arizona
    507
    The skid plate in your picture is not for a 350X. Perhaps it could be made to fit.
    Las Vegas, NV.
    2,538
    Quote Originally Posted by J!m View Post
    Still hoping to get that blue paint code!
    First off, I can't believe I still have a can of this paint. I don't recall using it on anything other than my '85 200X, so unless I'm mistaken, this can was purchased in Oct. 1984, and I used it to paint my front brake, master cylinder guard. I'm not sure if it's the color you're looking for, but it was almost identical to the OEM seat/fork boots color on the '85 200X, which would be the same blue on the 85-86 350X.
    Keep up the good work, and enjoy the journey!
    Arizona
    507
    Here is the OEM 350X skid plate for reference.
ID:	271936Click image for larger version.
    J!m's Avatar
    J!m is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2024
    New Haven, CT area
    210
    Cable came in!
    devore,ca
    1,056
    Does the decomp arm actually move when you cycle the kicker ?. About 50 percent of the ones I've seen are broken . They get broken when people remove the side cover to work on the clutch and don't bother to line everything back up again before they tighten the cover bolts.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    J!m's Avatar
    Nov 2024
    New Haven, CT area
    210
    I’m not sure honestly. The cable was missing so I needed it either way. I know that pin gets broken a lot, and it’ll be coming off, but hasn’t yet.
    J!m's Avatar
    Nov 2024
    New Haven, CT area
    210
    Wait-‘so this is the wrong skid plate?
    85/86 are different (but interchange)… what is that a picture of? I have to see if bolts line up now.
    Arizona
    507
    The picture I uploaded is the OEM skid plate that came off my 1986 350X. I took it off the bike when I got it and put an aftermarket one on because it was in perfect condition and I did not want to trash it riding in the desert.
    J!m's Avatar
    Nov 2024
    New Haven, CT area
    210
    Well that’s disappointing.
    I’ve reached out to the seller but not heard anything yet. Price was fair and maybe I can use the chain slider on the correct skid plate but if I can identify it I can sell it on if the seller won’t take it back.
    At least I sorted out some wheels. Rears from one seller and front from another. My current front wheel will be for sale very soon.
    Arizona
    507
    I'm pretty sure the skid plate you bought is for a 99-08 TRX400EX.
    J!m's Avatar
    Nov 2024
    New Haven, CT area
    210
    That’s a helpful guess. I’ll try to cross it with pictures.
    devore,ca
    1,056
    As far as the decomp function goes, Its not a pin that breaks, it's the casting itself that holds it in place. Just cycle the kick starter slowly while watching the actuator arm down at the top of the case. It should move. Having a broken decomp is no big thing, but having the broken pieces rolling around in there could be a problem. The decomp is a miss understood item. It has nothing to do with how easy (or hard) the engine will kick over. Its only there to help you get the engine to the compression stroke before you kick it. Unless you put a Goki on it you really don't need it. I have one now with a broken decomp and I was able to hook a cable to the parking brake to actuate it manually instead. I took the Goki off it and now I don't use the decomp at all and I don't notice any difference between the 350's I have with the with or with out the decomp when starting them.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    RZR XP 900
    J!m's Avatar
    Nov 2024
    New Haven, CT area
    210
    J!m's Avatar
    Nov 2024
    New Haven, CT area
    210
    Looks like a TRX400 skid plate. Less than $100 on eBay currently...
  15. #30
    Feb 2025
    Grand Rapids, MI
    20
    I see this paint is still available. 40 years later would you think it's still a close match to Honda ATC blue? I guess I could buy a can from Amazon and test it out.
