Page 4 of 10 FirstFirst ... 2 3 4 5 6 ... LastLast
Results 46 to 60 of 145
Thread: Let the games begin! (1986 350X project)
  1. #46
    Arizona
    507
    Most Honda part numbers with the exception of bolts and Hondaline accessories are split in 3 sections. The first section is the prefix which identifies the part. The second section is the bike code and the third section is the version or what makes it unique. Parts that have a Z or letters at the end in the third section indicate that this part is either a plastic part or a painted part and the letter codes indicate the color code.
    Lets use the 350X seat as an example:
    1985
    77100-HA5-000
    77100 = Seat
    HA5 = 350X
    000 = first version
    1986
    77100-HA5-670
    77100 = Seat
    HA5 = 350X
    670 = second version
    The parts that are all specific to the 350X will all have the HA5 designation. But that does not mean that Honda does not also use that part number on another bike. Take the red plastic taillight lens as an example.
    Lens, Taillight
    33302-965-003
    33302 = Lens, Taillight
    965 = 200X (1983-1985)
    003 = version
    This part first showed up on the 1983 200X but was also used on the 200x, 350x, 250r, 200s and trx250r. Case in point, Honda keeps the same part number and just uses it moving forward on whatever bike they choose to use it on. There are still bikes today that use parts like rubber grommets with an HA2 (85-86 250r) designation that have not changed since 1985.
    For bolts, it’s either a 2 section or 3 section part number
    First section is the type of bolt, ex: dish head flange bolt, over head, pan head, screw, etc…
    The second section is the size. Sometimes there is a third section that could be either finish type or version.
    96000-06010
    96000 - flange bolt
    06010 - 6mm diameter, 10mm long
    There are also bolts that are more specialized and are more specific to a bike or multiple bikes. These part numbers use the normal 3 section part number with the bike code they were originally made for.
    For Hondaline accessories it’s usually a 2 section part number. Example - Speedometer Gear Box for a 350x is 08175-HA500. 08175 = speedometer gearbox. HA5 = 350x.
    Hope this info helps.
  2. #47
    J!m's Avatar
    J!m is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2024
    New Haven, CT area
    181
    Got a nice muffler today! Still need a head pipe and heat shields but it’s getting there!
  3. #48
    J!m's Avatar
    Nov 2024
    New Haven, CT area
    181
    I put together a list of hardware to potentially purchase from bell metric or McMaster and quickly identified that diameter and length code.
  4. #49
    J!m's Avatar
    Nov 2024
    New Haven, CT area
    181
    Question: Is the 200X seat pan the same as the 350X seat pan?
    Obviously, they have different part numbers but without handling both I really have no idea, but maybe others here have had both and can let me know?
  5. #50
    J!m's Avatar
    Nov 2024
    New Haven, CT area
    181
    I managed to find pictures of both undersides- completely different.
  6. #51
    J!m's Avatar
    Nov 2024
    New Haven, CT area
    181
    Another puzzler for me…
    I took my headlight assembly off last night, and, well, I need to replace almost everything.
    But my question is the wiring of the lights to the switch: it seems the switch has connections for one light and of course we have two to light up… I don’t see any intermediate harness on the parts fiche or attached to headlight units I find for sale.
    Can someone post some pictures of how things are supossed to look back there? I can make whatever sub harness is needed but I’d like to at least follow the factory design if not get the correct harness to use there.
    Thank you!
  7. #52
    J!m's Avatar
    Nov 2024
    New Haven, CT area
    181
    I just answered my own question.
    The connectors on the end of (the correct) switch have a double-female barrel connection to accommodate both headlight's male barrel connectors. Many of the switches I'm seeing for sale do not have this "detail" correct... The switch on my trike is wrong; I assumed it to be an 85 switch, but it seems to be from a different trike- perhaps the 200X the wheels came from.
  8. #53
    J!m's Avatar
    Nov 2024
    New Haven, CT area
    181
    In case you weren't aware, I enjoy ADHD. So, were jumping in another direction. (this will happen a lot)
    I have new wheel bearings and tapered bearings for the triple tree; I may not need them, but I'd hate to have it apart and then have to wait for a bearing kit... So, the forks will come off. They don't appear to be leaking, but like my Defender, this may simply indicate they are empty... There's some "looseness" up front I haven't positively identified, but fork rebuild and new bearings should address it, I think.
    Lowers are in okay shape but need some cleaning up. I don't want to polish them; just return them to a clean original look. I did a search and was in the rabbit hole of posts of all sorts on front forks, including polishing techniques, but I just want some guidance like "I used XXX brand mag wheel cleaner, and they came out great!" sort of thing.
    Any other tips/tricks I simply MUST know before I start tearing things up further are also appreciated.
  9. #54
    J!m's Avatar
    Nov 2024
    New Haven, CT area
    181
    Just found this for solving the headlight switch wiring issue, in case anyone else has similar issues:
    https://www.ebay.com/itm/36527977932...Bk9SR47LgLDHZg
    Has the double-female barrel connector AND a vinyl sleeve to cover it (several, it seems) so not a bad deal. Get a similarly priced aftermarket switch and replace the connector. Done.
  10. #55
    devore,ca
    1,051
    Soft stainless wire wheel on a pedestal grinder works good for the fork lowers if you just want the brushed look. Get the softest and widest you can find. Good old Mothers mag/alum polish works good for me if you want a little shine.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
  11. #56
    J!m's Avatar
    Nov 2024
    New Haven, CT area
    181
    I could glass bead them but that looks different than the "fresh cast" look.
    I picked up some non-acid wheel cleaner today (to use on the wheels too) and I'll see how that does.
    I don't want bead blasted or brushed (certainly not polished) look. Just want them to look fresh(er).
  12. #57
    devore,ca
    1,051
Name:	86 350x-2.jpg
    Don't be afraid of a little bit of shine. The 86's look good with a little highlight.
    These fork legs were wire brushed then buffed with a wheel. No sanding.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    RZR XP 900
  13. #58
    J!m's Avatar
    Nov 2024
    New Haven, CT area
    181
    Sorry, kid. College is out of the question…
  14. #59
    Feb 2017
    Corona CA
    858
    Quote Originally Posted by BOB MARLIN View Post
Name:	86 350x-2.jpg
Name:	86 350x-2.jpg
    Bob, hello. How have you been ? Let’s talk about that un modifed gen 5 bronco sir.
  15. #60
    devore,ca
    1,051
    Hey Shawn,
    Been to Rasor lately ?.
    The bronco is a brick nose (‘90). 70,000 original miles and was parked for 17 years with a bad ecu. I wanted an OBS but for $4000 I couldn’t turn it down.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    RZR XP 900
