Page 8 of 10 FirstFirst ... 6 7 8 9 10 LastLast
Results 106 to 120 of 145
Thread: Let the games begin! (1986 350X project)
  1. #106
    Las Vegas, NV.
    2,538
    Quote Originally Posted by J!m View Post
    Build date is 3/86, so not a "late 85" build but I guess they ran studs for a while; perhaps into 87 even. Just found it interesting.
    You lost me there. So, you're saying the later models had bolts that held the disc to the hub, rather than studs/nuts? I switched to countersunk/flathead allen bolts for clearance reasons when I did the inverted forks on my 250R. Those studs were definitely a bit stubborn to remove after all those years.
  2. #107
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,250
    interesting,,,, all the 350x's i havebuilt been around and seen, i have never ever seen a bolted on front rotor,
  3. #108
    J!m's Avatar
    J!m is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2024
    New Haven, CT area
    212
    Well I’m sure mine was studs and u-nuts too, but if you look at the parts fiche, you’ll se the studs for 85 and bolts for 86. I guess we’ll see what they look like when they arrive.
    And the studs were set with locktite (or whatever Honda used). I took the other two out and chased the threads. I’m planning a fresh coat of paint in the morning along with the brake disc.
    Meanwhile at muppet labs, the triple tree is off the trike. Turns out it has tapered bearings but the grease… it’s clear and adhesive. The grinding noise was actually sticktion I think. I’ll clean that all out and repack them with proper marine grease. They also made a “seal” at the top with a bead of clear silly-cone. That peeled right off thanks to their lack of proper prep.
    Just… wrong.
    free online line deduplication
  4. #109
    J!m's Avatar
    Nov 2024
    New Haven, CT area
    212
    I have a spare Enkei front wheel n tire, 1185 date code for a 86 200x I suppose.
    Full DG exhaust (aluminum muffler variant)
    Set of handlebars with “Honda” pad on the crossbar. No idea what brand they are.
    Some of these brake line guides. I bought extras and will go with the best ones I have. I have to check the fiche because one of mine (the bottom one) is black and it doesn’t appear to be “”. I’ll see if there are two part numbers for 85&86 tomorrow.
    Rear handle for a cooler or some such. Aluminum I think.
    I’ll have some surplus hardware suitable for replating as well.
    I can get pictures if anything seems irresistible…
  5. #110
    J!m's Avatar
    Nov 2024
    New Haven, CT area
    212
    Only one part number for the "clamp, fr. brake hose" so I guess someone use their artistic license to spray the piece black. (at least they did a decent job)
  6. #111
    Las Vegas, NV.
    2,538
    About the black brake line guide, if you're referring to the "curved" one, if I remember correctly, it came that way from Honda. Some sort of plating process (perhaps zinc), I'm guessing, which produced a black/dark olive drab green finish. I remember painting mine silver, to match the forks better.
  7. #112
    devore,ca
    1,056
    My '86 has bolts for the rotor.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
  8. #113
    J!m's Avatar
    Nov 2024
    New Haven, CT area
    212
    Yeah, on the bottom brake line guide, it was zinc plated. The paint came right off, and its zinc plated under that. Cleaned up pretty nicely.
    It wasn't a black zinc or oxide; it was just painted in the past. In my case at least.
  9. #114
    Arizona
    509
    Quote Originally Posted by BOB MARLIN View Post
    Same. My '86 has bolts for the rotor as well. They still have the yellow paint marks on them from the factory.
  10. #115
    J!m's Avatar
    Nov 2024
    New Haven, CT area
    212
    Did they locktite those bolts too ? Maybe you dirtwheels haven’t found out if the paint is still on yours but I assume they did.
    It seemed like they might have used Hondabond or similar between the disc and hub too, or it was excessive corrosion. It’s gone now either way.
    So the bare aluminum has been cleared. It will dry until Monday, then I’ll mask that off and shoot the black. Brake disc is already donenn
  11. #116
    J!m's Avatar
    Nov 2024
    New Haven, CT area
    212
    Finally confirmed I have an 86 carb. Happy about that as they are not easy to find.
    Not happy about the “impact damage” it has however…
  12. #117
    J!m's Avatar
    Nov 2024
    New Haven, CT area
    212
    In other news: I hope to get the motor out this weekend. Probably won’t but I’m hoping.
    I think I need a left mid case besides the left cover. Would those who know better be able to determine if I need a center case or if it’s just the cover?
  13. #118
    Aug 2015
    Idaho
    863
    I didn’t see any mention of the shift lever in your picture-post #2. Although it may work, it’s about an inch too short, which suggests it’s from another model.
    Looks like your wanting this to be correct, anyway.
    Btw-congrats on the sweet find
  14. #119
    J!m's Avatar
    Nov 2024
    New Haven, CT area
    212
    I appreciate the input for sure!
    I got “burned” on the rear skid plate because I’m not attuned to the visual differences yet. Once the engine is out, I’ll address those issues. There is a lot of oil on top of the engine so a few issues will be addressed when the top end (at least) comes apart.
    Not sure what’s up with the pictures either.
  15. #120
    devore,ca
    1,056
    Oil on the top of the engine is probably from the rocker cover. There isn’t a gasket up there, just a light coat of sealant, and most people use the wrong sealant. Also, the bolts that hold it on are small and tend to strip the threads in the head making a leak. All which are very fixable.
    It appears you are some kind of machinist, or at least have access to a milling machine. That’s really handy when it comes to modifying old broken parts.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    RZR XP 900
