Results 1 to 3 of 3
Thread: 83 Honda ATC200
    Oct 2025
    Lake Norman NC
    3
    83 Honda ATC200
    What rear axle hubs will fit my 1983 Honda ATC200? I know the bolt pattern is different from most (4x150) but if I switched to another bolt pattern say 4x110 for example what other trike or quad hubs fit the axle? I'm looking to extend the rear wheels out a bit my factory hubs are starting to rot out. I see all sorts of stuff on 200s, 200e, 200m, 200es but nothing on the plain 200. Thanks!
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    444
    You should be able to use rear hubs from a Honda TRX250X, 300ex,400ex and/or 450R.
    This will give slightly more width and a 4 on 110mm bolt pattern.
    TRX450ER
    ATC250SX
    ATC350X
    ATC250ES
    ATC110
    ATC185S (Marlboro Red)
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    Feb 2017
    Corona CA
    858
    If you don’t want the width as mentioned above stock 200x hubs , same 4-110 bolt pattern but narrower than the 400ex line up.
