Check the aftermarket steering stem bearings to see if the part number is the same between the 200e and 250es .
You will need the entire front end from the 250es to make this work.
The brakes and front wheel will not interchange so if you use a different fork you will need the wheel and brakes that are designed to work with that fork.
The exception to this would be the ATC200M front forks.
TRX450ER
ATC250SX
ATC350X
ATC110
ATC185S (Marlboro Red)
XR100R
CRF230F
Raptor 125
Breeze 125
Grizzly700
