If you cant find a leak, check the jet in the middle of the carb, the one with all the little sideways holes in it. If one of those holes is the least bit clogged with the smallest speck of anything it will cause it to not run without the choke as well as other issues.
I've also had the threads to the adjustment screw holes and jet holes just wear out and leak around the threads.
YAMAHA 450 HYBRID
85 350X- RED
85 350x -BLACK
86 350x-WHITE (with Goki)
85 250r
83 atc 70
84 atc 70
84 atc 110
09 yfz 450
2006 Arctic Cat Prowler
RZR XP 900
