Thread: 250R idle issues
    Nov 2024
    Arizona
    5
    250R idle issues
    I just picked up a ‘85 250R all stock and i had got it running it was idling no issues then all of a sudden it didnt want to idle i tried retuning the carb and making sure my jets werent clogged or any other common issues but nothing. It only idles with choke on, any tips or tricks to fix this?
    Las Vegas, NV.
    2,527
    If everything is all stock, and perhaps original, on that 41 year old bike, the first thing I would suspect is an air leak, especially around the carburetor-to-reed valve boot.
    Nov 2024
    Arizona
    5
    How would i check that? just run it and spray with soapy water?
    Las Vegas, NV.
    2,527
    If nothing obvious is found via a visual inspection, you can try spraying WD-40 around the area while the bike is running. The idle will increase, if there is an air leak in that area, when it sucks in the WD-40.
    Nov 2024
    Arizona
    5
    Yeah ill try that with the WD-40 but nothing obvious with a visual inspection
    Las Vegas, NV.
    2,527
    Quote Originally Posted by TrikeBandit85 View Post
    If you're sure the carburetor is clean, I would suspect an air leak somewhere. If the WD-40 doesn't yield any results, a leak-down test may be in order.
    devore,ca
    1,051
    If you cant find a leak, check the jet in the middle of the carb, the one with all the little sideways holes in it. If one of those holes is the least bit clogged with the smallest speck of anything it will cause it to not run without the choke as well as other issues.
    I've also had the threads to the adjustment screw holes and jet holes just wear out and leak around the threads.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
