Results 1 to 11 of 11
Thread: Giving a dead a bigred another chance to ride again
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    442
    I recently got a 1985 ATC250es from a friend. It has been sitting in the woods for 5 to 10 years.
    I am having some questions for the forum so I decided to start a thread on this machine.
    i will get some photos as well.
    I noticed yesterday that there are holes in each of the tail light lenses in pretty much the same place.
    I am guessing that the bulbs got hot and melted the plastic lenses?
    My question is would this be caused by someone using the wrong bulbs, or could these lenses be low quality after market and the polymer just cannot handle the heat from the standard bulbs?
    Have any of you seen this before with the 2nd gen bigreds?
    TRX450ER
    ATC250SX
    ATC350X
    ATC250ES
    ATC110
    ATC185S (Marlboro Red)
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    Feb 2016
    Stellenbosch, South Africa
    196
    I have never seen bulbs melt these as they can take quite a bit of heat. Is it clear as day that it is melted holes? Could it not be knocked out in the same place by accident somehow?
    1983 Honda ATC250R
    1983 Honda ATC200E BIG RED (sold)
    1984 Honda ATC200E BIG RED
    1983 Honda ATC200X
    1984 Honda ATC200X (sold)
    1985 Honda ATC70 x 3
    1985 Honda ATC200ES BIG RED (FatCat Conversion)
    1985 Honda ATC250ES BIG RED
    1986 Honda ATC250ES BIG RED
    1988 Honda ATC250ES BIG RED
    1995 Honda Frankentrike 50cc 2-stroke
    2001 Honda TRX90
    2002 Yamaha Breeze 125 (sold)
    2004 Honda TRX300EX (sold)
    2008 Honda TRX250TM
    1976 Suzuki RV90M (sold)
    1967 Vespa Primavera 125
    1958 Massey Ferguson 35
    J!m's Avatar
    J!m is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2024
    New Haven, CT area
    210
    I just refurbished a tail light that had a 20W bulb inside. It should be a 5W bulb and they are not easy to find.
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    442
    The holes are in the middle of the lenses on both taillights.
    I have not taken these apart yet but I assume the bulbs are in the center of the tail light.
    I will check the watts at some point and that is good info for sure.
    At this point I am working towards hearing the engine run and the transmission go through the gears.
    I hope to start it in the next day or so.
    TRX450ER
    ATC250SX
    ATC350X
    ATC250ES
    ATC110
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    442
    Quote Originally Posted by J!m View Post
    I might try a LED bulb if I can find one that fits the tail lights.
    TRX450ER
    ATC250SX
    ATC350X
    ATC250ES
    ATC110
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    Jan 2026
    northwest indiana
    4
    Holes in the middle sound like someone at one time put the blueish lenses in the center for the different colored tail lights?
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    442
    I have gotten far enough with this project to ride it around the yard. All of the gears shift so i am happy about that.
    TRX450ER
    ATC250SX
    ATC350X
    ATC250ES
    ATC110
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    442
    Seems like most of the fuel petcocks from amazon or ebay have a fuel spigot that is too small (usually around 5mm).
    I ordered one from Caltric (also ebay) and the fuel spigot is about 8mm which is about the size from honda but the strainer screen does not fit (too big) into the aftermarket plastic fuel tank.
    Seems like nothing is ever easy with these machines.
    TRX450ER
    ATC250SX
    ATC350X
    ATC250ES
    ATC110
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    Aug 2015
    Idaho
    862
    Footy, did it come with 2 sealing washers? A round o-ring washer is used without the filter and the flat washer is used with the filter.
    Oem Petcock came with one sealing washer at the tank and it can only be used in conjunction with the filter. If you don’t use the filter, you need another sealing washer and also install an inline filter.
    Feb 2016
    196
    Agree with the inline filter, I have them on all my bikes for extra peace of mind
    1983 Honda ATC250R
    1983 Honda ATC200X
    2001 Honda TRX90
    2008 Honda TRX250TM
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    442
    Quote Originally Posted by Jd110 View Post
    I am planning to use an inline filter.
    There was only 1 oring with this petcock but I trimmed down the screen so that the plastic base is seated into the petcock as it would have been if the screen would have fit into the fuel tank.
    TRX450ER
    ATC250SX
    ATC350X
    ATC250ES
    ATC110
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
