Thread: 185s front sprocket help
    Nov 2023
    nottingham
    Hi from the uk, I have a 82 185s that I'm restoring and could use some advise on the front sprocket . I bought it as a wreck have no idea what the previous owners did to it as it was a wreck but I was a bit surprised that the front sprocket was just held on with a circlip on the end of the driveshaft and no stop at all on the engine side , is this how it is supposed to be ? My sprocket has three threaded holes for a retainer if it ever had one at all?
    Apr 2006
    London Ontario, Canada
    1,199
    The front sprocket was held on by a clip that was bolted to the sprocket. I believe that they are discontinued. When I had my xr600, the front sprocket was held on the output shaft by the same method that you described. I never had an issue with the chain rubbing on the cases. I'm working on a 1983 185s at the moment, I'm going to run the xr200 front sprocket with the 2 bolt retaining clip.
    R.I.P. Sandpuppie, you are greatly missed!
    May you rest in peace Jeswinehart, deeply missed, never forgotten....
    Feedback thread http://www.3wheelerworld.com/showthr...ight=tapper190
    Nov 2023
    nottingham
    great ,thanks for the info
    J!m's Avatar
    J!m is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2024
    New Haven, CT area
    210
    See the f you can download the parts fiche. That, and the workshop manual help connect the dots where prior owners have taken “liberties” in Their repair and upkeep activities.
