Results 1 to 3 of 3
Thread: 350x front fork rebuild?
    Nov 2002
    39
    Is all you need to do a rebuild on the front forks of a 350x -- the 2 seals for each side from honda or is there a lot more involved? how difficult is this to do? and I know the recommended air pressure for the forks is neutral with the front off the ground, but what if you weigh 240lbs? how much is too much? I'm afraid I'll be doing this all over again if I overpressurize them! I plan on changing the fork oil when I do this, will this help on bottoming out?
    so many hills, so little time
    ATCnut is offline Got The Holeshot Arm chair racerJust too addicted
    Nov 2002
    Auburn Washington
    799
    Most people just replace the seals when they start leaking, and call that a rebuild. There are a bunch of other metal parts in the forks that can wear, a full rebuild is replacing all of those too.
    ATCnut
    82 185s - sold
    83 200x (hopped up)
    84 200x (stock)
    84 70 (lost this one to the DMV)
    85 70 (soon to have lights, a foot brake, and CDI ignition)
    84 200es (parts trike) - sold
    85 350X (the best)
    85 350X (siezed motor, dream of a poweroll kit someday)
    85 250sx (frame was trash, got parted out)
    86 250sx (the tractor)
    86 250sx (a nicer tractor)
    86 250sx (an even nicer tractor)
    87 200x (parts trike, its really rough, a dog was chewing on it for a while)
    87 250es Big Red (the tank!!)
    Clarks Summit PA
    1,236
    i thk most people would agree... dont put air in your shocks... just put new seals in.. measure your springs to make sure they are still in specs, and refill the oil.. that will be a good rebuild job.. if the old seals were blown, you will feel the difference,, and if you put air in them, the air will need to go somewhere when you compress them hard, and so will the seals..
    Ride it like you stole it! And never look back! They are too far behind to see!
