Results 1 to 10 of 10
Thread: Will this axle bearing carrier fit the 1986 350X swingarm?
    J!m's Avatar
    J!m is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2024
    New Haven, CT area
    210
    Talking specifically with the 86 350X and it's cast carrier with the large slots (for the Allen wrench to adjust).
    I can see mine is not stock- it is a billet aftermarket carrier. Nice, but not correct. Original carriers are hard to find but there is a cast aftermarket one that looks "right" yet is listed for other models-
    https://www.ebay.com/itm/32702489780...G51FR24XX499TV
    Anyone try one of these?
    Trying to cross parts and the internal bearings are the same part number (if I remember correctly- I looked at a lot of stuff in a short time), but I'm not sure about lengths and outside diameter (but the exterior o-rings seems to be the same too).
    So, it SEEMS to be "right" but I was hoping for a second opinion before I spend more money.
    Las Vegas, NV.
    2,538
    If you want to trust what bikes these aftermarket sellers claim these fit, here is some good news. This manufacturer says this will fit the 1986 350X, and also the 1992-2012 TRX 300EX: https://www.ebay.com/itm/13372048633...Bk9SR6Kt8_yeZw
    Now, this bearing carrier, in the style you like, says it fits 1997-2009 TRX 300EX: https://www.ebay.com/itm/28200636032...BlBMUKKt8_yeZw
    While it doesn't specifically list the 1986 350X, it does give a glimmer of hope.
    J!m's Avatar
    Nov 2024
    New Haven, CT area
    210
    Yeah, that's part of the reason I was asking.
    These guys will say anything to sell stuff... hoping it is not returned for a refund later.
    I compared bearing part numbers and external O-ring numbers below:
    1992 TRX300:
    Bearing- 91051-HA2-013
    O-ring- 91353-HA2-003/-005
    Carrier- 52201-HC0-670 / HM3-000
    1986 350X:
    Bearing-91051-HA2-003/-013
    Carrier- 52201-HA5-670
    In theory, it should fit fine... Might be wider overall, or some other problem...
    PS: I just discovered the collar between the bearings is the same part number... (42621-HA5-000) So, the spacing might just be the same here!!
    Las Vegas, NV.
    2,538
    Quote Originally Posted by J!m View Post
    Exactly! And if you order it for a bike not listed in their fitment guide, you would probably have difficulty returning it. In my experience with ATC 250R and TRX 250R stuff (which a whole lot interchanges), a lot of the time, the ATC will not be listed as proper fitment, but the TRX 250R will. If a reputable, aftermarket manufacturer says it will interchange, I would believe it. But as these bikes get older, they get forgotten. Even LSR's website doesn't list 350X bearing carriers anymore, but they used to. You might try contacting them, and ask about 350X stuff. They might just divulge what, if anything, interchanges.
    https://lsracing.com/
    J!m's Avatar
    Nov 2024
    New Haven, CT area
    210
    Looking at an original (crusty) carrier for the 86 350X, these options we've found have a wider area outside the swingarm. That means, they'd (probably) have to be machined down for clearance of the sprocket hub. Maybe.
    I may just find a crusty original to deburr and media blast, if it's structurally sound. I had hoped to have a workable solution moving forward...
    J!m's Avatar
    Nov 2024
    New Haven, CT area
    210
    Note the thickness of the flange for the chain adjustment:
    https://www.ebay.com/itm/397372623761
    Las Vegas, NV.
    2,538
    They both look like the standard OEM flange thickness to me. I don’t see the issue, nor the need to possibly machine it down.
    J!m's Avatar
    Nov 2024
    New Haven, CT area
    210
    Look where the wrench goes in to turn it- those "nubs" are considerably thicker than the original, which is essentially flat on the open end.
    Maybe it clears just fine, but it is considerably different.
    Las Vegas, NV.
    2,538
    Yeah I see what you mean now.
    You just have to use the 86 sprocket bolts and the countersunk sprocket.
    It's better to use them on the 85 setup (thinner carrier) too because if the chain come off it won't get wrapped up in the bolts and chew the carrier all up. I have the 86 bolts here at home and on Ebay.
