Results 1 to 15 of 16
Thread: the next rabbit hole. 350x
    az
    2,043
    never look at marketplace when your bored. 350x for 1200 bucks, I had to go look. turns out to be a 85 with a 400ex motor adapted in there. not running. im trying to decide if finding a 350x motor and getting it back to stock or replacing the 400ex motor with the same and doing it nicer makes more sense, or trade it for some other trike project like a 200x because ive got spare 185s motors to make a auto easier.
    Does a 185s motor fit in a 350x chassis? jim
    Attached Thumbnails Attached Thumbnails Resized_Screenshot_20260325_165118_Facebook_375914977002951.jpeg
    81 185s
    82 185s with 85 200s motor
    82 185s
    and a 72 ct70
    az
    2,043
    unloading it.
    81 185s
    82 185s
    and a 72 ct70
    J!m's Avatar
    J!m is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2024
    New Haven, CT area
    210
    85 engine parts are pretty plentiful.
    As long as the frame has not been cut, I'd go that route.
    My problem is I have an 86 and there are a lot fewer parts to select from in my case.
    I do have an 85 bottom end that I presume to be good internally, but I got it in parts along with my trike so I have no idea on it's condition.
    az
    2,043
    it looks like the bottom back engine mounts been chopped. I put a couple ads out locally to see if theres a 350xotor available or another 400ex wrecked quad. Hopefully something comes along. jimClick image for larger version.
ID:	272088Click image for larger version.
    81 185s
    82 185s
    and a 72 ct70
    az
    2,043
    theres 2 250x quads local with 350x motors in them, one says not running and smoked when it did run, another just not running. prices are 1200 and 800 which is a bit much of a gamble for me. The seller told me he was told the topend was making noise per the person he got it from. After thinking about it, I think im going to try and figure out the wiring and see if I can get the 400ex motor running. carb and exhaust is already on there. it looks like it was all together at some time. Theres a little hackery on the frame. if i can get it running, ill order the adapter kit from atc adt and install it properly. it came with a oil cooler and custom oil tank. im thinking I tossed all my extra 350D parts like oil lines and coolers.
    I did find a guy with a 350x bottom end he might let go, ive got a extra cylinder, head, cam rockerbox intake etc.
    Hopefully I can find a simple diagram how to get this to start and charge when I get busy on it. jim
    81 185s
    82 185s
    and a 72 ct70
    az
    2,043
    81 185s
    82 185s
    and a 72 ct70
    az
    2,043
    81 185s
    82 185s
    and a 72 ct70
    devore,ca
    1,056
    I have a complete '85 350x engine. Runs fine , shifts fine and if I remember correctly the decomp actually works.
    BUT it smokes horribly. Maybe just valve seals, who knows. I also have a seat that's in better condition than that.
    I'm in so. cal. , not too bad of a drive for you. Or I'll sell you the whole parts bike if you want. It's missing the front wheel, gas tank and a few other small things.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    az
    2,043
    you know that probably makes the most sense to buy a donor trike and put the two together. why cant stuff show up a little closer. jim
    81 185s
    82 185s
    and a 72 ct70
    devore,ca
    1,056
    7 or 10 years ago it wasn't too bad to ship parts anywhere. I have sold and shipped ATC parts across the U.S, Canada and even some to Sweden. Now shipping cost so much that many times its just not worth it. The last frame I sold cost more to ship than I sold it for.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    RZR XP 900
    az
    2,043
    I know, socal is probably a 7 to 8 hour 1 way trip. some of the family is going to Disney in a few weeks. unfortunately theres no room in their suburban for a trike. jim
    81 185s
    82 185s
    and a 72 ct70
    az
    2,043
    got the brake master cylindered deluverd, so hopefully get it the brakes working soon
    ordered a engine bolt kit, get it sealed up then try amd figure the minimum wires I need to get it to spin over and hopefully get some spark and see if it runs. local guy has a complete wiring harness for a 400ex so Iay grab it.
    If the motor works, that'll save quite a bit
    Got a reply on my want ad locally and might see if i can pick up a 350x motor if the guy is interested in a 6 inch stainless ruger gp100 jim
    81 185s
    82 185s
    and a 72 ct70
    az
    2,043
    got a motor for the trike this afternoon! had to buy a whole 87 250sx to get the 350x motor. came with pipes and 350x headlights. owner said he got it to run 1 time and it smoked. seems to have lots of compression, got a title to tje quad, going to harvest the rear tires and wheels, 350x headlights, motor.
    So whats a 87 250sx quad worth without a motor? jim
    81 185s
    82 185s
    and a 72 ct70
    az
    2,043
    update, the frankenquad is now running, so hopefully the motor comes out soon, gotta get a title for the 350x then the motor gets installed,
    headlights and rear tires installed. then sell the 250quad roller, and 400ex core motor.
    lastly get pics posted on the pist. jim
    81 185s
    82 185s
    and a 72 ct70
    az
    2,043
    title is done on the 350x. Now to decide is it worth doing or sell both with titles and settle with my 200x that I dont really ride jim
    81 185s
    82 185s
    and a 72 ct70
