Thread: Blueing
    Aug 2015
    Idaho
    862
    Blueing
    I did this to the axle center and brake hub. Not sure yet if it will work, yet.
    Anyone else try it?
    It all started with this sleeve:
    I thought it was good so I did a little more, anyway. If you want to, lmk if it’s bad.
    J!m's Avatar
    J!m is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2024
    New Haven, CT area
    205
    Is that a cold blue, like for gun touchup, or something else?
    Aug 2015
    Idaho
    862
    Yes, that’s right. It is a cold blueing liquid. Although, I heated the inner axle to get it warm. I’ll take it apart next year to see how it held up. I’ve only read that the grease will help the longevity of the blueing.
    J!m's Avatar
    Nov 2024
    New Haven, CT area
    205
    Proper hot blueing is an oxide layer on the surface, sort of like a passivation that occurs to aluminum and titanium.
    Sealing with grease or a hard wax will definitely improve the lifetime.
